.Arduino: 1.5.8 (Mac OS X), Board: "Arduino Uno"
In file included from temperature.ino:2:0:
/Users/dansaffer/Documents/Arduino/libraries/Adafruit_TMP006/Adafruit_TMP006.h:31:29: fatal error: Adafruit_Sensor.h: No such file or directory
#include <Adafruit_Sensor.h>
compilation terminated.
Error compiling.
I went to Adafruit's Github and found Adafruit_Sensor.h from another project and put it in the library directory. Then I got this error when compiling:
Any ideas?In file included from /Users/dansaffer/Documents/Arduino/libraries/Adafruit_TMP006/Adafruit_TMP006.h:31:0,
/Users/dansaffer/Documents/Arduino/libraries/Adafruit_TMP006/Adafruit_Sensor.h:13:40: error: invalid suffix "c667986764fec48bdcb746baef4bd8653096e23" on integer constant
<title>xGlove/Adafruit_Sensor.h at 0c667986764fec48bdcb746baef4bd8653096e23 · teundeplanque/xGlove · GitHub</title>
/Users/dansaffer/Documents/Arduino/libraries/Adafruit_TMP006/Adafruit_Sensor.h:13:5: error: stray '\302' in program
/Users/dansaffer/Documents/Arduino/libraries/Adafruit_TMP006/Adafruit_Sensor.h:13:5: error: stray '\267' in program
/Users/dansaffer/Documents/Arduino/libraries/Adafruit_TMP006/Adafruit_Sensor.h:304:56: error: invalid suffix "c66798676" on integer constant
<span class="js-select-button css-truncate-target">0c66798676</span>
/Users/dansaffer/Documents/Arduino/libraries/Adafruit_TMP006/Adafruit_Sensor.h:413:13: error: stray '`' in program
<a href="/teundeplanque/xGlove/commit/170172d4fa4329d14473431e25d84ff815e2a753" class="message" data-pjax="true" title="Spark core code`">Spark core code`</a>
/Users/dansaffer/Documents/Arduino/libraries/Adafruit_TMP006/Adafruit_Sensor.h:545:54: error: stray '#' in program
<td id="LC20" class="blob-code js-file-line">#<span class="pl-k">ifndef</span> _ADAFRUIT_SENSOR_H</td>
/Users/dansaffer/Documents/Arduino/libraries/Adafruit_TMP006/Adafruit_Sensor.h:549:54: error: stray '#' in program
<td id="LC21" class="blob-code js-file-line">#<span class="pl-k">define</span> <span class="pl-en">_ADAFRUIT_SENSOR_H</span></td>
/Users/dansaffer/Documents/Arduino/libraries/Adafruit_TMP006/Adafruit_Sensor.h:558:54: error: stray '#' in program
<td id="LC23" class="blob-code js-file-line">#<span class="pl-k">include</span> <span class="pl-s1"><span class="pl-pds">"</span>application.h<span class="pl-pds">"</span></span></td>
/Users/dansaffer/Documents/Arduino/libraries/Adafruit_TMP006/Adafruit_Sensor.h:584:54: error: stray '#' in program
<td id="LC29" class="blob-code js-file-line">#<span class="pl-k">define</span> <span class="pl-en">SENSORS_GRAVITY_EARTH</span> (<span class="pl-c1">9</span>.<span class="pl-c1">80665F</span>) <span class="pl-c">/**< Earth's gravity in m/s^2 */</span></td>
/Users/dansaffer/Documents/Arduino/libraries/Adafruit_TMP006/Adafruit_Sensor.h:584:199: error: invalid suffix "F" on integer constant
/Users/dansaffer/Documents/Arduino/libraries/Adafruit_TMP006/Adafruit_Sensor.h:588:54: error: stray '#' in program
<td id="LC30" class="blob-code js-file-line">#<span class="pl-k">define</span> <span class="pl-en">SENSORS_GRAVITY_MOON</span> (<span class="pl-c1">1</span>.<span class="pl-c1">6F</span>) <span class="pl-c">/**< The moon's gravity in m/s^2 */</span></td>
/Users/dansaffer/Documents/Arduino/libraries/Adafruit_TMP006/Adafruit_Sensor.h:588:199: error: invalid suffix "F" on integer constant
/Users/dansaffer/Documents/Arduino/libraries/Adafruit_TMP006/Adafruit_Sensor.h:592:54: error: stray '#' in program
<td id="LC31" class="blob-code js-file-line">#<span class="pl-k">define</span> <span class="pl-en">SENSORS_GRAVITY_SUN</span> (<span class="pl-c1">275</span>.<span class="pl-c1">0F</span>) <span class="pl-c">/**< The sun's gravity in m/s^2 */</span></td>
/Users/dansaffer/Documents/Arduino/libraries/Adafruit_TMP006/Adafruit_Sensor.h:592:201: error: invalid suffix "F" on integer constant
/Users/dansaffer/Documents/Arduino/libraries/Adafruit_TMP006/Adafruit_Sensor.h:596:54: error: stray '#' in program
<td id="LC32" class="blob-code js-file-line">#<span class="pl-k">define</span> <span class="pl-en">SENSORS_GRAVITY_STANDARD</span> (SENSORS_GRAVITY_EARTH)</td>
/Users/dansaffer/Documents/Arduino/libraries/Adafruit_TMP006/Adafruit_Sensor.h:600:54: error: stray '#' in program
<td id="LC33" class="blob-code js-file-line">#<span class="pl-k">define</span> <span class="pl-en">SENSORS_MAGFIELD_EARTH_MAX</span> (<span class="pl-c1">60</span>.<span class="pl-c1">0F</span>) <span class="pl-c">/**< Maximum magnetic field on Earth's surface */</span></td>
/Users/dansaffer/Documents/Arduino/libraries/Adafruit_TMP006/Adafruit_Sensor.h:600:200: error: invalid suffix "F" on integer constant
/Users/dansaffer/Documents/Arduino/libraries/Adafruit_TMP006/Adafruit_Sensor.h:604:54: error: stray '#' in program
<td id="LC34" class="blob-code js-file-line">#<span class="pl-k">define</span> <span class="pl-en">SENSORS_MAGFIELD_EARTH_MIN</span> (<span class="pl-c1">30</span>.<span class="pl-c1">0F</span>) <span class="pl-c">/**< Minimum magnetic field on Earth's surface */</span></td>
/Users/dansaffer/Documents/Arduino/libraries/Adafruit_TMP006/Adafruit_Sensor.h:604:200: error: invalid suffix "F" on integer constant
/Users/dansaffer/Documents/Arduino/libraries/Adafruit_TMP006/Adafruit_Sensor.h:608:54: error: stray '#' in program
<td id="LC35" class="blob-code js-file-line">#<span class="pl-k">define</span> <span class="pl-en">SENSORS_PRESSURE_SEALEVELHPA</span> (<span class="pl-c1">1013</span>.<span class="pl-c1">25F</span>) <span class="pl-c">/**< Average sea level pressure is 1013.25 hPa */</span></td>
/Users/dansaffer/Documents/Arduino/libraries/Adafruit_TMP006/Adafruit_Sensor.h:608:202: error: invalid suffix "F" on integer constant
/Users/dansaffer/Documents/Arduino/libraries/Adafruit_TMP006/Adafruit_Sensor.h:612:54: error: stray '#' in program
<td id="LC36" class="blob-code js-file-line">#<span class="pl-k">define</span> <span class="pl-en">SENSORS_DPS_TO_RADS</span> (<span class="pl-c1">0</span>.<span class="pl-c1">017453293F</span>) <span class="pl-c">/**< Degrees/s to rad/s multiplier */</span></td>
/Users/dansaffer/Documents/Arduino/libraries/Adafruit_TMP006/Adafruit_Sensor.h:612:199: error: invalid digit "9" in octal constant
/Users/dansaffer/Documents/Arduino/libraries/Adafruit_TMP006/Adafruit_Sensor.h:616:54: error: stray '#' in program
<td id="LC37" class="blob-code js-file-line">#<span class="pl-k">define</span> <span class="pl-en">SENSORS_GAUSS_TO_MICROTESLA</span> (<span class="pl-c1">100</span>) <span class="pl-c">/**< Gauss to micro-Tesla multiplier */</span></td>
/Users/dansaffer/Documents/Arduino/libraries/Adafruit_TMP006/Adafruit_Sensor.h:1068:55: error: stray '#' in program
<td id="LC148" class="blob-code js-file-line">#<span class="pl-k">endif</span></td>
/Users/dansaffer/Documents/Arduino/libraries/Adafruit_TMP006/Adafruit_Sensor.h:5:1: error: expected unqualified-id before '<' token
<!DOCTYPE html>
/Users/dansaffer/Documents/Arduino/libraries/Adafruit_TMP006/Adafruit_Sensor.h:558:136: error: expected unqualified-id before '<' token
/Users/dansaffer/Documents/Arduino/libraries/Adafruit_TMP006/Adafruit_Sensor.h:558:183: error: expected unqualified-id before '<' token
/Users/dansaffer/Documents/Arduino/libraries/Adafruit_TMP006/Adafruit_Sensor.h:697:56: error: expected unqualified-id before '<' token
<td id="LC57" class="blob-code js-file-line">} <span class="pl-s3">sensors_type_t</span>;</td>
/Users/dansaffer/Documents/Arduino/libraries/Adafruit_TMP006/Adafruit_Sensor.h:697:98: error: expected unqualified-id before '<' token
Error compiling.
