Max 31855 Thermocouple Shield
hdhillon90
Post by hdhillon90 »
Hello there. I bought this shield about a month or so ago and wanted to get some help on an issue I am having. When I upload the code onto the Arduino and open the Serial monitor, the thermocouple has errors, rather excessively. I bought a thermocouple cable from the website and I have it attached to a female adapter which extends the thermocouple further out. The pictures below should explain how my setup is. The end of the thermocouple is a long lead which is used to measure water temperature in a pot. Any Idea why I would get so many thermocouple errors? Thanks
Female adapter. Black cable coming from the thermocouple shield.
Lead of the thermocouple.
Franklin97355
Re: Max 31855 Thermocouple Shield
Post by Franklin97355 »
Have you tested the circuit with the thermocouple connected directly to the board? What errors are you getting and what code are you running? Is this a shield or the breakout board?
hdhillon90
Yes I have tested the circuit with the thermocouple plugged directly into the board, and this does not cause any errors. Only when i extend it with the female adapter, i get the error in the serial monitor saying Thermocouple error. The code I am using is the one from the adafruit library named serial thermocouple.
Franklin97355
The problem seems to be the extension. How far are you extending the leads?
hdhillon90
The extension is roughly 3.25 ft.
adafruit2
Post by adafruit2 »
could be something is loose in the extender, or you flipped wires? or the thermocouple is picking up RF and that's messing up the measurements. we've extended a thermocouple by about a meter and it was OK so its *techinically* possible :)
What are you using to extend the thermocouple? Extending it with standard copper wire will defeat the cold-junction compensation and lead to temperature errors. You should only extend a thermocouple with thermocouple extension wire of the same type as your thermocouple (type K in this case).
