Quetion about led matrix 40
Wilty
Post by Wilty »
I need to know, i bought a pcduino nano 3, this shield is compatible? is just that, look i need an arduino with flash memory and output audio 3.5 mm, and the respectives o/i for this shield... i find pcduino with all of this features...
Franklin97355
Re: Quetion about led matrix 40
Post by Franklin97355 »
The shield uses digital pin 6 to communicate and Neopixels are not happy sharing interrupts so be aware of that when using mixed code. It also does not work well on OSes that are preemptive like Linux due to the tight communications requirements. Check with the pcduino folks to see what they think.
Wilty
Post by Wilty »
Yep, linux based developed systems have some problems with ws2812's... but they said, a seril link could do the works. Could you suggest an arduino system? i need a mp3 player+neopixels shield to do a digital spectrum (like media player) the thing is manipulate the matrix and play the songs at the same time ;F...
Maybe with raspberry ?
Return to “Other Arduino products from Adafruit”
