Sous Vide Issues Compiling Code
AtrumEquus
Post by AtrumEquus »
I'm a bit of a noob when it comes to using the Arduino but I could use some help figuring out what the issue is with setting up the code that was presented in the pdf.
Error code I received:
Arduino: 1.0.6 (Windows 7), Board: "Arduino Mega 2560 or Mega ADK"
Sous_Vidiuno_Rev1:62: error: 'PID' does not name a type
Sous_Vidiuno_Rev1:79: error: 'PID_ATune' does not name a type
Sous_Vidiuno_Rev1.ino: In function 'void setup()':
Sous_Vidiuno_Rev1:178: error: 'myPID' was not declared in this scope
Sous_Vidiuno_Rev1.ino: In function 'void Off()':
Sous_Vidiuno_Rev1:246: error: 'myPID' was not declared in this scope
Sous_Vidiuno_Rev1:246: error: 'MANUAL' was not declared in this scope
Sous_Vidiuno_Rev1:262: error: 'AUTOMATIC' was not declared in this scope
Sous_Vidiuno_Rev1.ino: In function 'void Run()':
Sous_Vidiuno_Rev1:497: error: 'myPID' was not declared in this scope
Sous_Vidiuno_Rev1.ino: In function 'void DoControl()':
Sous_Vidiuno_Rev1:573: error: 'aTune' was not declared in this scope
Sous_Vidiuno_Rev1:580: error: 'myPID' was not declared in this scope
Sous_Vidiuno_Rev1.ino: In function 'void StartAutoTune()':
Sous_Vidiuno_Rev1:639: error: 'myPID' was not declared in this scope
Sous_Vidiuno_Rev1:642: error: 'aTune' was not declared in this scope
Sous_Vidiuno_Rev1.ino: In function 'void FinishAutoTune()':
Sous_Vidiuno_Rev1:656: error: 'aTune' was not declared in this scope
Sous_Vidiuno_Rev1:661: error: 'myPID' was not declared in this scope
Got the code from: https://github.com/adafruit/Sous_Viduino
PID Library: http://playground.arduino.cc/Code/PIDLibrary version 1.0.1
PID Auto tune: http://playground.arduino.cc//Code/PIDAutotuneLibrary version 0.0.0
Onewire: http://www.pjrc.com/teensy/td_libs_OneWire.html version 2.2
DS18B20 Sensor: http://www.milesburton.com/?title=Dalla ... ary#Github version 3.7.2
RGB LCD Sheild: Got from the adafruit website I already tested a hello world it works fine.
Attached a picture showing that the zip files are in my Arduino Library
adafruit_support_mike
Re: Sous Vide Issues Compiling Code
You need to unzip the files, rename the folders so the Arduino IDE will accept them, then move those into your sketchbook/libraries folder.
This tutorial has more information about installing libraries:
https://learn.adafruit.com/adafruit-all ... -libraries
