Hi - I'm soldering the protoshield and I have a 6-pin female header in place of one of the 5-pin headers. (In other words, I was sent two 5-pins and one 6-pin.) How do I get the correct replacement?
Also, there are pins interfering with each other when I place the protoshield on top of the Uno R3. The SCL pins from 10-pin female header are touching the SDA SCL (male) pins on the Uno. Can you please advise?
Mary
Wrong female header sent
- Franklin97355
Re: Wrong female header sent
Can you post some pictures of the problem? You should have 2x6 pin 2x8 pin and 3x5 pin You can cut the extra pin off if you want to get on with the build or contact [email protected] for an extra header.
