Arduino Uno,Fingerprint Scanner, SFGDemo communication issue
yonci9
Post by yonci9 »
I am currently trying to enroll new fingerprints by using SFGdemo with Arduino Uno. I soldered extra wires in order to get a better contact and wired up the sensor as described in https://learn.adafruit.com/downloads/pd ... sensor.pdf. Before connecting the sensor to Arduino, I uploaded the blank sketch and then connected the sensor to Arduino. I entered the COM PORT which Arduino using. However, I am continuously getting a message" Open device fail ". Could you inform me what might be the problem please?
adafruit_support_rick
Re: Arduino Uno,Fingerprint Scanner, SFGDemo communication i
Unfortunately, I've seen this issue with SFGDemo. There are two possible problems. How long does it take before the error message pops up?
If it happens immediately, it is a problem with SFGDemo itself that I've never been able to overcome.
If it takes a few seconds for the error message to pop up, then it's a problem with your wiring.
yonci9
Post by yonci9 »
Unfortunately,Error message is appearing too quick. Is there any other software which I can use to enroll fingerprints instead of SFGdemo?
That is an infuriating problem. I have the same problem on my Windows 7 machine. I've never been able to get it to work. Sorry.
You can use our Arduino example sketch for enrolling.
https://learn.adafruit.com/adafruit-opt ... th-arduino
