DotStar faulty operation
unic8
Post by unic8 »
just bought 4 meter of the DotStar 60 LED/meter (so actually 240 overall) and wired it to some Arduino compatible boards (Micro and Pro Trinket) with the "strandtest" example code of the official Adafruit library.
https://www.youtube.com/watch?v=KBhQ7gE4mfk
The exteral power supply got 5V 2A.
The LEDs are blinking wild and without any noticeable logic. What am I doing wrong or am I missing? Is this maybe caused by a defect?
Regards,
Erik
Franklin97355
Re: DotStar faulty operation
Post by Franklin97355 »
Do you have a ground between the strip power and the micro?
unic8
Post by unic8 »
Thanks for your response!
No, I don't have ground between the Micro board and the DotStar strip.
I just hooked up the ground from the external supply.
My current wiring setup is pin 4 and 5 for clock and data like described in the example code.
How should I hook up ground between the strip and the board?
Instead or additional to the current ground to the power supply?
Thanks for the support!
Regards
Franklin97355
Run a wire from the power supply ground or the strip ground to the microcontroller ground.
unic8
Post by unic8 »
Thank you so much! Works perfect with correct wiring.
Have a great day
Return to “Other Arduino products from Adafruit”
