I need help with understanding the logic behind your fingerprint sensor library library,
How do I enroll a fingerprint in the sensor with a different type of microcontroller other than Arduino, i've read the datasheet for a few minutes but i don't seem to implement the instructions in the datasheet, the datasheet is not clear and it's in chinese.
The most import thing in the datasheet according to me, is the Flow chart which is in image format and it's also written in Chinese, i tried translating the document using googleTranslate but the translator isn't smart enough translate words embedded in an Image,
I would request someone to make a rough sketch of a flow chart of how to enroll a finger in the fingerprint without using the Library, i.e. showing hex codes to communicate the sensor with a host computer.
In the attachment are the flow chart images in the device datasheet(ZFM-206SA33)
Thank you.
Customizing Adafruit's FingerPrint Library
- electronicsalim
- Attachments
- chinese flow chart
- entry_flowchart.jpg (51.92 KiB) Viewed 271 times
- flowchart.jpg (47.36 KiB) Viewed 271 times
- adafruit_support_rick
Re: Customizing Adafruit's FingerPrint Library
Your best bet is to port the adafruit library to your processor. Even the translated version of the datasheet will drive you crazy.
https://github.com/adafruit/Adafruit-Fi ... or-Library
