I bought through Amazon the NFC/RFID breakout oard from here: http://www.amazon.com/gp/product/B00KKU ... UTF8&psc=1
When I connect to the Arduino Uno, after the Hello! appears, this appears:
Didn't find PN53x board
Please help.
P.D. I have noted that the 1.6v doesn't have that logo.
I directly uploaded it to Photobucket. The link is http://s376.photobucket.com/user/inakin ... uino/story
I soldered it fine with no shorts because I checked continuity between the pins with a multimeter.
PN53x error not being recognized
- adafruit_support_rick
Re: PN53x error not being recognized
It's difficult to trace your wiring in the pictures. Double-check that you are wired to the level shifter pins correctly.
- inakineitor
I already have double checked the circuit and there is no problem with the wiring.
- Franklin97355
Could you post the code you are running?
- inakineitor
I am using the code example from the library to test the card that comes with the package.
- Franklin97355
Could you post a photo that better shows your connections or at least tell us what you have connected where?
