Current Sensor INA169 not working
EngZach
Post by EngZach »
So I bought three current sensors for my Arduino controller to monitor as three multiple conditions. While testing them, I can't get them to work. In my serial monitor I'm getting all zeroes (0.000 A). I measured the current with a multimeter and got 0.010 A. During my investigation in to the issue, I tried measuring the current through the VCC (5V) and ground and found that it was 0 A. (wondering if there was a bad batch of these chips..?). I used multiple controllers to ensure it was not a bad controller. Basically I found that there was not continuity in any of the chips. Ideas? I'm using an Arduino Uno, however, I also tried using a Digilent ChipKit Uno32. Unfortunately, I need this resolved ASAP, I have a project deadline in just under 2 weeks.
// Constants
const int SENSOR_PIN = A0;  // Input pin for measuring Vout
const int RS = 10;          // Shunt resistor value (in ohms)
const int VOLTAGE_REF = 5;  // Reference voltage for analog read
// Global Variables
float sensorValue;   // Variable to store value from analog read
float current;       // Calculated current value
  // Initialize serial monitor
  Serial.begin(1200);
  // Read a value from the INA169 board
  sensorValue = analogRead(SENSOR_PIN);
  // Remap the ADC value into a voltage number (5V reference)
  sensorValue = (sensorValue * VOLTAGE_REF);
  sensorValue = map(sensorValue,0,1023,0.000,6.000);
  // Follow the equation given by the INA169 datasheet to
  // determine the current flowing through RS. Assume RL = 10k
  // Is = (Vout x 1k) / (RS x RL)
  current = sensorValue / (10 * RS);
  // Output value (in amps) to the serial monitor to 3 decimal
  // places
  Serial.print(current, 3);
  Serial.println(" A");
Here is the breadboard, I'm 99.9% sure everything is hooked up properly.
Re: Current Sensor INA169 not working
You have not soldered any of your connections. All of the header pins need to be soldered.
http://learn.adafruit.com/adafruit-guid ... -soldering
EngZach
Post by EngZach »
All soldered up. Still getting all zeroes.
adafruit_support_mike
In the photo above, you don't have anything connected to the Vin+ and Vin- pins.
Those are the sense pins. You have to connect something to those for the chip to have something to measure.
EngZach
Post by EngZach »
They're wired in series with an LED circuit powered with a 6v power supply. They are connected through the breadboard. And the LED works.
Sorry, I was looking at the empty pads for the terminal blocks.
Try taking a voltage measurement between GND and OUT while the LED is lit. It should read about 10mV.
EngZach
Post by EngZach »
It measures zero.
Thanks. Could you post another photo of your setup showing the soldering?
reyge
Post by reyge »
I can't seem to create a new post so I am replying to this thread for now.
Were you able to solve your INA169 problem?
I recently bought two units of this breakout board. Using a lab bench power supply, I tried passing 0.1A to 1A of current but the output is always about 10mV. This happens on the two boards I bought. I haven't connected my Arduino or other circuit to the breakout board. What do you think is the problem? Have you encountered this problem before?
I can't seem to create a new post...
If you go to the top of this forum, there is a "Post A Topic" button.
viewforum.php?f=22
Return to “Other Arduino products from Adafruit”
