I upgraded to 1.6.4 and have been using the SD Master library for my SD card storage applications. Now I get the following:
Multiple libraries were found for "SD.h"
Used: /Users/brucewarren/Arduino/Arduino.app/Contents/Java/libraries/SD
Not used: /Users/brucewarren/Arduino/libraries/SDMaster
The older version had a SD library as well as my included SDMaster library but I did not get this error.
Has something changed or do I need to stop using SDMaster, or delete SD from Arduino library?
IDE version 1.6.4_SD library issues
- cbrucewarren
Re: IDE version 1.6.4_SD library issues
I tried temporarily moving the SD library out of the Arduino content folder.
However, now I get the following error message:
--------------------start
/Users/brucewarren/Arduino/libraries/AdafruitVC0706Camera/Adafruit_VC0706.cpp:68:9: error: prototype for 'uint8_t Adafruit_VC0706::setMotionStatus(uint8_t, uint8_t, uint8_t)' does not match any in class 'Adafruit_VC0706'
uint8_t Adafruit_VC0706::setMotionStatus(uint8_t x, uint8_t d1, uint8_t d2) {
In file included from /Users/brucewarren/Arduino/libraries/AdafruitVC0706Camera/Adafruit_VC0706.cpp:18:0:
/Users/brucewarren/Arduino/libraries/AdafruitVC0706Camera/Adafruit_VC0706.h:89:11: error: candidate is: boolean Adafruit_VC0706::setMotionStatus(uint8_t, uint8_t, uint8_t)
boolean setMotionStatus(uint8_t x, uint8_t d1, uint8_t d2);
Error compiling.
-----------------end
Is there an updated VC0706 libary i need to get?
Any ideas as to what is wrong will be appreciated!
Error compiling.
- Franklin97355
I believe there was a change in the newer IDE that checked for more errors/warnings. Download the latest library and see if it helps.
- cbrucewarren
Yes, that got it!
However, new issue: ( it's been awhile since I used the camera circuit, but I did have it working in the past) Now the camera is not being recognized ("camera not found"). Wiring is OK per tutorial.
Side note: photo of board in tutorial shows power connection labeled as "5V" on the board, my board shows "3.5", spec sheet says operates on 5 and I've connected power connection to 5v.
I've tried to use the CommTool, but when I test connection by trying to get version, i get "cmd timed out" message.
Any thoughts/hints??
