I have a question relating to the download of images from the TTL serial camera. I have been through the tutorial and taken a look at the code, but I cannot find a ready answer to my questuion.
Once you have taken a picture, in what form is the data from the camera buffer downloaded, is it one continuous stream of data start to finish, or can you request the data in a particular block size ?
If you can request it in blocks, can you request specific blocks, say block1, block2, blockn etc ?
TTL Serial Camera
- adafruit_support_rick
Re: TTL Serial Camera
It's just a serial stream. No block orientation at all.
- srnet
Thanks for the prompt reply.
That is what I wanted to know.
- marcelops
I know the Adafruit camera (product ID #397, listed on https://www.adafruit.com/products/397 ) can operate at 30 fps.
My questions are:
1) Can Arduino handle that amount of data?
2) If Arduino can't do that, what would be the alternative?
I am planning on using a camera like this one to capture videos and save it (the frames) to a SD card. What would be the fastest rate (in fps) that Arduino would be able to handle?
Marcelo
My questions are:
Marcelo
Not a chance of it. You simply can't write to an SD that fast. The camera does 30fps video, but it takes maybe 10-15 seconds to download an image via serial.
- marcelops
Would it be better (faster) if I used a 32-bit chip, like the one in the Anduino Due, or the Zero?
- srnet
I would think you could write the data first to an SPI RAM (23LC1024 or similar) or maybe a FRAM, these will run at 16Mhz clock.
Then copy from there to a SD card at your leisure.
The problem is that the camera downloads images over serial. It's just not that fast. You can't do video with it.
- marcelops
Hi Rick,
Thanks for replying.
I understand that communication over serial isn't fast, but sometimes it is "fast enough" for some applications.
That said, considering I use a 32-bit chip (as the Arduino Due) and the Adafruit camera (product ID #397), how fast (in fps) would I be able to transfer images over serial, from the camera to a SD card? Is there a number (in fps) we could rely on? 1 fps? 2fps? 0.5 fps? With that number, we can assess whether it would be enough or not for a certain application.
Marcelo
Marcelo
It's on the order of 10-15 seconds, regardless of processor.
- marcelops
Alright!! At least now I know!! ;-)
In that case, the next question is: "Is there an alternative for this task?"
I would need to save snapshots in the order of 15 fps (or faster) to a SD card. Is there a non-serial camera, or any device, or anything we could use to save the pictures faster? Any suggestion is appreciated!
Marcelo
Marcelo
You would need a computer with video capture hardware to sample the video stream.
I believe there are video capture modules you can get for the Raspberry Pi. I don't know anything about them, though:
https://www.google.com/search?client=sa ... 8&oe=UTF-8
