Dear Adafruit admin
I use adafruit library for fingeprint in this link https://github.com/adafruit/Adafruit-Fi ... gerprint.h
And I got a problem, when i use getImage(), my program will reset to beginning. I combine Fingerprint with RTC and use Arduino Uno board.
Is there an explanation about this?
Problem With Adafinger print
- adafruit_support_rick
Re: Problem With Adafinger print
Does the unmodified example "fingerprint" sketch work?
- bernadusdl
The example sketch is work.
I already solved this problem, by make new function for RTC DS1307. But I dont know why Fingerprint and RTC can't work at the same function
And this is my final sketch
And this is my sketch if i dont use new function
#include <Wire.h>
#include <RTClib.h>
#include <LiquidCrystal.h>
#include <Adafruit_Fingerprint.h>
#include <SoftwareSerial.h>
#include <Ethernet.h>
#include <SPI.h>
SoftwareSerial mySerial (2,3);
Adafruit_Fingerprint finger=Adafruit_Fingerprint(&mySerial);
int id;
RTC_DS1307 rtc;
int days;
int months;
int years;
int hours;
int minutes;
int seconds;
int totalsec1;
int totalsec2;
String data,date,time;
LiquidCrystal lcd (A2,A3,7,6,5,4);
bool stats=0,statm=0,statp=0;
byte mac[]={0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
char server[]="testing.ngrok.io";
IPAddress ip(192,168,0,177);
EthernetClient client;
Wire.begin();
rtc.begin();
rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
pinMode(A0, OUTPUT);
pinMode(A1, OUTPUT);
lcd.begin(16,2);
finger.begin(57600);
if(Ethernet.begin(mac)==0){
Serial.println("Failed to configure Ethernet using DHCP");
Ethernet.begin(mac,ip);
delay(1000);
Serial.println("connecting...");
if (finger.verifyPassword())
Serial.println("Found fingerprint sensor!");
} else
Serial.println("Did not find fingerprint sensor :(");
Serial.println("Waiting for valid finger...");
rtcfunction();
date="";
time="";
data="";
makestring();
if(hours>=6&&minutes>=30&&0<=totalsec1&&totalsec1<=5400)
statm=0;
statp=1;
digitalWrite(A0, HIGH);
digitalWrite(A1, LOW);
getFingerprintID();
if(stats==1)
makedata();
senddata();
stats=0;
lcd.setCursor(0,0);
lcd.print("MENGIRIM DATA ");
delay(3000);
else if(hours>=16&&0<=totalsec2&&totalsec2<=5400)
statm=1;
statp=0;
getFingerprintID();
if(stats==1)
makedata();
senddata();
stats=0;
lcd.setCursor(0,0);
delay(3000);
else
digitalWrite(A0, LOW);
digitalWrite(A1, HIGH);
lcd.setCursor(0,0);
lcd.print("ABSEN DITUTUP ");
lcd.setCursor(0,1);
lcd.print(date);
lcd.print(" ");
lcd.print(time);
lcd.print(" ");
delay(1000);
void rtcfunction(){
DateTime rtcdata = rtc.now();
years=rtcdata.year();
months=rtcdata.month();
days=rtcdata.day();
hours=rtcdata.hour();
minutes=rtcdata.minute();
seconds=rtcdata.second();
DateTime dt0(years,months,days,6,30,0);
DateTime dt1(years,months,days,16,0,0);
DateTime dt2(years,months,days,hours,minutes,seconds);
TimeSpan ts0=dt2-dt0;
TimeSpan ts1=dt2-dt1;
totalsec1=ts0.totalseconds();
totalsec2=ts1.totalseconds();
Serial.println(totalsec1);
Serial.println(totalsec2);
void makestring(){
date= String (years);
date.concat("-");
date.concat(months);
date.concat("-");
date.concat(days);
time= String (hours);
time.concat(":");
time.concat(minutes);
void makedata(){
time.concat(":");
time.concat(seconds);
if (statm==0&&statp==1)
data= String("ID=");
data.concat(id);
data.concat("&&");
data.concat("tanggal=");
data.concat(date);
data.concat("&&");
data.concat("waktum=");
data.concat(time);
data.concat("waktup=00:00:00");
if (statm==1&&statp==0);
data.concat(id);
data.concat("&&");
data.concat(date);
data.concat("&&");
data.concat("waktup=");
data.concat(time);
data.concat("waktum=00:00:00");
void senddata(){
if(client.connect(server,80))
Serial.println("connected");
client.print("GET /absen/coba.php?");
client.print(data);
client.println(" HTTP/1.1");
client.println("Host:testing.ngrok.io");
client.println("Connection:close");
client.println();
client.stop();
else{
Serial.println("connection failed/n");
delay(300000);
uint8_t getFingerprintID() {
uint8_t p = finger.getImage();
switch (p) {
case FINGERPRINT_OK:
lcd.setCursor(0,0);
lcd.print("IMAGE TAKEN ");
break;
case FINGERPRINT_NOFINGER:
lcd.setCursor(0,0);
lcd.print("SILAHKAN ABSEN ");
return p;
case FINGERPRINT_PACKETRECIEVEERR:
lcd.setCursor(0,0);
lcd.print("COM. ERROR ");
return p;
case FINGERPRINT_IMAGEFAIL:
lcd.setCursor(0,0);
lcd.print("IMAGE ERROR ");
return p;
default:
lcd.setCursor(0,0);
lcd.print("UNKOWN ERROR ");
return p;
// OK success!
p = finger.image2Tz();
switch (p) {
lcd.setCursor(0,0);
lcd.print("IMAGE CONVERT ");
break;
case FINGERPRINT_IMAGEMESS:
lcd.setCursor(0,0);
lcd.print("IMAGE MESSY ");
return p;
lcd.setCursor(0,0);
lcd.print("COM.ERROR ");
return p;
case FINGERPRINT_FEATUREFAIL:
lcd.setCursor(0,0);
lcd.print("NO FINGER FEAT.");
return p;
case FINGERPRINT_INVALIDIMAGE:
lcd.setCursor(0,0);
return p;
default:
lcd.setCursor(0,0);
return p;
// OK converted!
p = finger.fingerFastSearch();
if (p == FINGERPRINT_OK) {
lcd.setCursor(0,0);
stats=1;
} else if (p == FINGERPRINT_PACKETRECIEVEERR) {
lcd.setCursor(0,0);
return p;
} else if (p == FINGERPRINT_NOTFOUND) {
lcd.setCursor(0,0);
lcd.print("NOT FIND MATCH ");
return p;
} else {
lcd.setCursor(0,0);
return p;
// found a match!
id=finger.fingerID;
lcd.setCursor(0,0);
lcd.print("ID=");
lcd.print(id);
lcd.print(" CONF=");
lcd.print(finger.confidence);
delay(3000);
#include <Wire.h>
#include <RTClib.h>
#include <SPI.h>
int id;
RTC_DS1307 rtc;
int days;
int months;
int years;
int hours;
int minutes;
int seconds;
int totalsec1;
int totalsec2;
Wire.begin();
rtc.begin();
lcd.begin(16,2);
delay(1000);
} else
days=rtcdata.day();
date="";
time="";
data="";
makestring();
statm=0;
statp=1;
getFingerprintID();
if(stats==1)
makedata();
senddata();
stats=0;
lcd.setCursor(0,0);
lcd.print("MENGIRIM DATA");
delay(3000);
statm=1;
statp=0;
getFingerprintID();
if(stats==1)
makedata();
senddata();
stats=0;
lcd.setCursor(0,0);
delay(3000);
else
lcd.setCursor(0,0);
lcd.print("ABSEN DITUTUP");
lcd.setCursor(0,1);
lcd.print(date);
lcd.print(" ");
lcd.print(time);
lcd.print(" ");
delay(1000);
void makestring(){
date.concat("-");
date.concat("-");
date.concat(days);
time.concat(":");
void makedata(){
time.concat(":");
data.concat(id);
data.concat("&&");
data.concat(date);
data.concat("&&");
data.concat(time);
data.concat(id);
data.concat("&&");
data.concat(date);
data.concat("&&");
data.concat(time);
void senddata(){
client.print(data);
client.println();
client.stop();
else{
delay(300000);
switch (p) {
lcd.setCursor(0,0);
break;
lcd.setCursor(0,0);
return p;
lcd.setCursor(0,0);
return p;
lcd.setCursor(0,0);
return p;
default:
lcd.setCursor(0,0);
return p;
// OK success!
switch (p) {
lcd.setCursor(0,0);
break;
lcd.setCursor(0,0);
return p;
lcd.setCursor(0,0);
return p;
Serial.println("Could not find fingerprint features");
return p;
return p;
default:
Serial.println("Unknown error");
return p;
// OK converted!
lcd.setCursor(0,0);
stats=1;
Serial.println("Communication error");
return p;
Serial.println("Did not find a match");
return p;
} else {
return p;
// found a match!
id=finger.fingerID;
lcd.setCursor(0,0);
lcd.print("ID=");
lcd.print(id);
delay(3000);
Sorry. I don't know either. There should be no conflict at all.bernadusdl wrote:But I dont know why Fingerprint and RTC can't work at the same function
- pixlux
In file included from C:\Users\pc4less615\Documents\Arduino\libraries\boubess/Adafruit_Fingerprint.h:19:0,
from enroll.ino:17:
C:\Users\pc4less615\Documents\Arduino\libraries\SoftwareSerial/SoftwareSerial.h:95:16: error: conflicting return type specified for 'virtual void SoftwareSerial::write(uint8_t)'
virtual void write(uint8_t byte);
In file included from C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Stream.h:26:0,
from C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/HardwareSerial.h:29,
from C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:223,
from C:\Users\pc4less615\Documents\Arduino\libraries\boubess/Adafruit_Fingerprint.h:18,
from enroll.ino:17:
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Print.h:48:20: error: overriding 'virtual size_t Print::write(uint8_t)'
virtual size_t write(uint8_t) = 0;
Error compiling.
help me please
from enroll.ino:17:
from enroll.ino:17:
Error compiling.
help me please
Let's continue this on your other thread:
viewtopic.php?f=22&t=73336&p=379906#p380096
