I am trying to get the Ultimate GPS to work with the Mega. It works fine with an Uno and not with the Mega. I am using the parsing example (Latest library). I have commented, and uncommented the two lines to use Mega Serial1 and RX1(Pin 19)/TX1(Pin 18).
To troubleshoot this problem, I loaded the blank example and the GPS is working through the Mega serial as it should. I loaded the parsing example (unmodified) on both Uno and Mega and wired the GPS the same to both. I get good serial output from the Uno, but not the Mega. I have two Megas, they both produce the same results.
I expect the first question you have is to see a picture so you can check my soldering and wiring. The problem is I have the GPS installed in a custom 3D printed mini shield made for the Mega so the wiring is not easy to get pictures of. I removed the shield and plugged it into two breadboards to access the pins for the GPS. From the troubleshooting listed above, I found the shield is properly wired and soldering is good because I can make it work with the Uno. The only changes I made between tests are the connection to the Arduinos. I have attached pictures of my testing and the results from the serial monitor.
Any ideas why the GPS is not working with the Mega?
Ultimate GPS Parsing with Mega
- davegun
- Uno Test Setup and Results
- UnoTest_Result.jpg (150 KiB) Viewed 1321 times
- Mega Test Setup & Results
- MegaTest_Result.jpg (148.21 KiB) Viewed 1321 times
- Project Configuration
- Project+.jpg (117.98 KiB) Viewed 1321 times
- davegun
Re: Ultimate GPS Parsing with Mega
I new it had to be something simple. I have used the Ultimate GPS with the Flora and Micro so I looked at my old code and got it to work. Here is my changes to the "Parsing" example to make it work using the Mega Serial1.
I still don't know why Software Serial didn't work with the Mega, but I have what I need for my project to work.
// Test code for Adafruit GPS modules using MTK3329/MTK3339 driver
// This code shows how to listen to the GPS module in an interrupt
// which allows the program to have more 'freedom' - just parse
// when a new NMEA sentence is available! Then access data when
// desired.
// Tested and works great with the Adafruit Ultimate GPS module
// using MTK33x9 chipset
// ------> http://www.adafruit.com/products/746
// Pick one up today at the Adafruit electronics shop
// and help support open source hardware & software! -ada
#include <Adafruit_GPS.h>
#include <SoftwareSerial.h>
// DAVES MOD - Start //
Adafruit_GPS GPS(&Serial1);
HardwareSerial mySerial = Serial1;
// DAVES MOD - END //
// Set GPSECHO to 'false' to turn off echoing the GPS data to the Serial console
// Set to 'true' if you want to debug and listen to the raw GPS sentences.
#define GPSECHO true
// this keeps track of whether we're using the interrupt
// off by default!
boolean usingInterrupt = false;
void useInterrupt(boolean); // Func prototype keeps Arduino 0023 happy
void setup()
// connect at 115200 so we can read the GPS fast enough and echo without dropping chars
// also spit it out
Serial.begin(115200);
Serial.println("Adafruit GPS library basic test!");
// 9600 NMEA is the default baud rate for Adafruit MTK GPS's- some use 4800
GPS.begin(9600);
// uncomment this line to turn on RMC (recommended minimum) and GGA (fix data) including altitude
GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCGGA);
// uncomment this line to turn on only the "minimum recommended" data
//GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCONLY);
// For parsing data, we don't suggest using anything but either RMC only or RMC+GGA since
// the parser doesn't care about other sentences at this time
// Set the update rate
GPS.sendCommand(PMTK_SET_NMEA_UPDATE_1HZ); // 1 Hz update rate
// For the parsing code to work nicely and have time to sort thru the data, and
// print it out we don't suggest using anything higher than 1 Hz
// Request updates on antenna status, comment out to keep quiet
GPS.sendCommand(PGCMD_ANTENNA);
// the nice thing about this code is you can have a timer0 interrupt go off
// every 1 millisecond, and read data from the GPS for you. that makes the
// loop code a heck of a lot easier!
useInterrupt(true);
delay(1000);
// Ask for firmware version
mySerial.println(PMTK_Q_RELEASE);
// Interrupt is called once a millisecond, looks for any new GPS data, and stores it
SIGNAL(TIMER0_COMPA_vect) {
char c = GPS.read();
// if you want to debug, this is a good time to do it!
#ifdef UDR0
if (GPSECHO)
if (c) UDR0 = c;
// writing direct to UDR0 is much much faster than Serial.print
// but only one character can be written at a time.
#endif
void useInterrupt(boolean v) {
if (v) {
// Timer0 is already used for millis() - we'll just interrupt somewhere
// in the middle and call the "Compare A" function above
OCR0A = 0xAF;
TIMSK0 |= _BV(OCIE0A);
usingInterrupt = true;
} else {
// do not call the interrupt function COMPA anymore
TIMSK0 &= ~_BV(OCIE0A);
uint32_t timer = millis();
void loop() // run over and over again
// in case you are not using the interrupt above, you'll
// need to 'hand query' the GPS, not suggested :(
if (! usingInterrupt) {
// read data from the GPS in the 'main loop'
if (GPSECHO)
if (c) Serial.print(c);
// if a sentence is received, we can check the checksum, parse it...
if (GPS.newNMEAreceived()) {
// a tricky thing here is if we print the NMEA sentence, or data
// we end up not listening and catching other sentences!
// so be very wary if using OUTPUT_ALLDATA and trytng to print out data
//Serial.println(GPS.lastNMEA()); // this also sets the newNMEAreceived() flag to false
if (!GPS.parse(GPS.lastNMEA())) // this also sets the newNMEAreceived() flag to false
return; // we can fail to parse a sentence in which case we should just wait for another
// if millis() or timer wraps around, we'll just reset it
if (timer > millis()) timer = millis();
// approximately every 2 seconds or so, print out the current stats
if (millis() - timer > 2000) {
timer = millis(); // reset the timer
Serial.print("\nTime: ");
Serial.print(GPS.hour, DEC); Serial.print(':');
Serial.print(GPS.minute, DEC); Serial.print(':');
Serial.print(GPS.seconds, DEC); Serial.print('.');
Serial.println(GPS.milliseconds);
Serial.print("Date: ");
Serial.print(GPS.day, DEC); Serial.print('/');
Serial.print(GPS.month, DEC); Serial.print("/20");
Serial.println(GPS.year, DEC);
Serial.print("Fix: "); Serial.print((int)GPS.fix);
Serial.print(" quality: "); Serial.println((int)GPS.fixquality);
if (GPS.fix) {
Serial.print("Location: ");
Serial.print(GPS.latitude, 4); Serial.print(GPS.lat);
Serial.print(", ");
Serial.print(GPS.longitude, 4); Serial.println(GPS.lon);
Serial.print("Location (in degrees, works with Google Maps): ");
Serial.print(GPS.latitudeDegrees, 6);
Serial.print(", ");
Serial.println(GPS.longitudeDegrees, 6);
Serial.print("Speed (knots): "); Serial.println(GPS.speed);
Serial.print("Angle: "); Serial.println(GPS.angle);
Serial.print("Altitude: "); Serial.println(GPS.altitude);
Serial.print("Satellites: "); Serial.println((int)GPS.satellites);
- Riley_Hosman
I spent three days trying to figure this out with my ultimate gps sheild and my mega- Thanks Dave!!! :)
I put a print statement after every command in the in setup().. From those I saw it always fail after one of the GPS.sendCommand() functions, secifically GPS.sendCommand(PMTK_SET_NMEA_UPDATE_1HZ); .
Putting in Dave's code fixed this :)
Change:
Adafruit_GPS GPS(&mySerial);
To:
I'm not too sharp on C++ classes, but maybe the problem can also be fixed in the adafruit_gps.h file? Maybe something with the #ifdef statements.. Here is the Adaftuit_GPS class the adafruit_gps.h:
Also I notice the switch needs to be on Soft Serial for it to work. Once it gets started, you can switch it back to direct, however. I'll need to figure this out for my project.
Thanks for the fix Dave.
Change:
To:
class Adafruit_GPS {
public:
void begin(uint16_t baud);
#ifdef __AVR__
#if ARDUINO >= 100
Adafruit_GPS(SoftwareSerial *ser); // Constructor when using SoftwareSerial
#else
Adafruit_GPS(NewSoftSerial *ser); // Constructor when using NewSoftSerial
#endif
#endif
Adafruit_GPS(HardwareSerial *ser); // Constructor when using HardwareSerial
char *lastNMEA(void);
boolean newNMEAreceived();
void common_init(void);
void sendCommand(const char *);
void pause(boolean b);
boolean parseNMEA(char *response);
uint8_t parseHex(char c);
char read(void);
boolean parse(char *);
void interruptReads(boolean r);
boolean wakeup(void);
boolean standby(void);
uint8_t hour, minute, seconds, year, month, day;
uint16_t milliseconds;
// Floating point latitude and longitude value in degrees.
float latitude, longitude;
// Fixed point latitude and longitude value with degrees stored in units of 1/100000 degrees,
// and minutes stored in units of 1/100000 degrees. See pull #13 for more details:
// https://github.com/adafruit/Adafruit-GPS-Library/pull/13
int32_t latitude_fixed, longitude_fixed;
float latitudeDegrees, longitudeDegrees;
float geoidheight, altitude;
float speed, angle, magvariation, HDOP;
char lat, lon, mag;
boolean fix;
uint8_t fixquality, satellites;
boolean waitForSentence(const char *wait, uint8_t max = MAXWAITSENTENCE);
boolean LOCUS_StartLogger(void);
boolean LOCUS_StopLogger(void);
boolean LOCUS_ReadStatus(void);
uint16_t LOCUS_serial, LOCUS_records;
uint8_t LOCUS_type, LOCUS_mode, LOCUS_config, LOCUS_interval, LOCUS_distance, LOCUS_speed, LOCUS_status, LOCUS_percent;
private:
boolean paused;
uint8_t parseResponse(char *response);
#ifdef __AVR__
#if ARDUINO >= 100
SoftwareSerial *gpsSwSerial;
#else
NewSoftSerial *gpsSwSerial;
#endif
#endif
HardwareSerial *gpsHwSerial;
};l
