Greetings everyone. I'm having an issue with the above item. It seems to be working great but I'm having a problem with getting red to show up when I try to place that particular color parameter into a variable e.g.
if I just do strip.setPixelColor(0, strip.Color(255, 0, 0);
Then red shows up just fine as well as green and blue
However, if I do int pxlColor = strip.Color(255, 0, 0); and then strip.setPixelColor(0, pxlColor);
Then red does not show up at all for any of the LED's but it works perfectly fine for both green and blue!
The sketch examples provided also work great and each individual led seem to be functioning properly including displaying red.
Just don't know what else to try. I'm using the Arduino IDE 1.6.4 if that makes any difference.
Thanks for any help
NeoPixel 16 LED ring help
- Obyah
- Disciple
Re: NeoPixel 16 LED ring help
I think a 32-bit variable is needed there. Try substituting this.Obyah wrote:However, if do int pxlColor = strip.Color(255, 0, 0); and then strip.setPixelColor(0, pxlColor);
uint32_t pxlColor = strip.Color(255, 0, 0);
Hallelujah!
Disciple
- Obyah
Hallelujah!
That did the job! Thank you so much Disciple!
