I want to use the TCS34725 with an Arduino UNO to functionally test some 8mm RGB LEDs with integrated WS2811.
Ideally, it would even test color consistency between LEDs and allow me to select a 'matched' subset of RGB LEDs.
I setup a small dark box with the sensor in one end a test RGB LED in the other with no other external light source.
I turn off the TCS34725 on-board white LED.
I modified the colorsensor sketch such that I drive my RGB LED with RED data from 0 to 1 to 2 to 4 etc... to 128 and repeat the same with GREEN, BLUE and then WHITE. That is my basic test. My sketch is extremely simple but giving me unexpected results.
I have changed the integrationtime and gain settings but find that the only way I get consistent results is if I add a significant delay between the tcs.getRawData(&red, &green, &blue, &clr); commands... as much as 1 or 2 seconds !?
i would definitely like to speed-up that test, Any suggestions ?
TCS34725 parameters
- jpro56
TCS34725 parameters
- Attachments
- Here's the data I get when I only have 100msec delay between tcs.getRawData
- TCS34725_data.PNG (28.92 KiB) Viewed 454 times
- Franklin97355
Re: TCS34725 parameters
Perhaps, if you post your code and a description or drawing of your connections between it all we can help. Please use the code button "</>" ori would definitely like to speed-up that test, Any suggestions ?
tags when posting code to the forums.
- jpro56
Here's the sketch...
#include <Wire.h>
#include "Adafruit_TCS34725.h"
#define NUM_LEDS 1 // Data pin that led data will be written out over
#define DATA_PIN 8 // Clock pin only needed for SPI based chipsets when not using hardware SPI
Adafruit_TCS34725 tcs = Adafruit_TCS34725(TCS34725_INTEGRATIONTIME_154MS, TCS34725_GAIN_60X);
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUM_LEDS, DATA_PIN, NEO_RGB + NEO_KHZ800);
Serial.begin(9600);
Serial.println("Color View Test!");
if (tcs.begin()) {
Serial.println("Found sensor");
} else {
Serial.println("No TCS34725 found ... check your connections");
while (1); // halt!
tcs.setInterrupt(true); // turn off LED
pixels.begin(); // This initializes the NeoPixel library.
Serial.print("RED: ");
Serial.println();
int i = 0;
pixels.setPixelColor(0, pixels.Color(i,0,0));
pixels.show();
sense(i);
for (i=1; i<=255; i = i<<1){
pixels.show();
sense(i);
i = 255;
pixels.show();
sense(i);
Serial.print("GREEN: ");
Serial.println();
i = 0;
pixels.setPixelColor(0, pixels.Color(0,i,0));
pixels.show();
sense(i);
pixels.show();
sense(i);
i = 255;
pixels.show();
sense(i);
Serial.print("BLUE: ");
Serial.println();
i = 0;
pixels.setPixelColor(0, pixels.Color(0,0,i));
pixels.show();
sense(i);
pixels.show();
sense(i);
i = 255;
pixels.show();
sense(i);
Serial.print("WHITE: ");
Serial.println();
i = 0;
pixels.setPixelColor(0, pixels.Color(i,i,i));
pixels.show();
sense(i);
pixels.show();
sense(i);
i = 255;
pixels.show();
sense(i);
void sense(int i){
delay(100);
uint16_t clr, red, green, blue;
Serial.print("I: "); Serial.print(i);
Serial.print("\tC: "); Serial.print(clr);
Serial.print("\tR: "); Serial.print(red);
Serial.print("\tG: "); Serial.print(green);
Serial.print("\tB: "); Serial.print(blue);
Serial.println();
#include <Wire.h>
Serial.begin(9600);
if (tcs.begin()) {
} else {
while (1); // halt!
Serial.println();
int i = 0;
pixels.show();
sense(i);
pixels.show();
sense(i);
i = 255;
pixels.show();
sense(i);
Serial.println();
i = 0;
pixels.show();
sense(i);
pixels.show();
sense(i);
i = 255;
pixels.show();
sense(i);
Serial.println();
i = 0;
pixels.show();
sense(i);
pixels.show();
sense(i);
i = 255;
pixels.show();
sense(i);
Serial.println();
i = 0;
pixels.show();
sense(i);
pixels.show();
sense(i);
i = 255;
pixels.show();
sense(i);
void sense(int i){
delay(100);
Serial.println();
- jpro56
and here's a few pictures of my setup...
- Attachments
- sensor setup
- WIN_20150813_20_20_13_Pro.jpg (91.49 KiB) Viewed 438 times
- sensor setup
- WIN_20150813_20_19_45_Pro.jpg (85.97 KiB) Viewed 438 times
- Franklin97355
You might try reducing the delay(100) to a smaller number as your loop takes 1.7 minutes because of that alone.
- jpro56
The problem I get when reducing that time is with wrong readings from the sensor.
If you look at the listing in my initial post when the main loop just went through red at max brightness (255), all 3 LEDS are turned off and I get a almost the same value from the sensor as if it was still red at max brightness (255) !?!?
Looks like data was still being latched from sensor !?!? That is the problem.,
