I bought an Adafruit TCA9548A breakout and got it working with two Adafruit BNO055 breakouts and an Arduino UNO. I plugged the three breakouts into a half-size breadboard.
At first, it did not work due to sluggish I2C pullups. I added 2.2K pullups to the Arduino's I2C lines, now it works fine.
I don't see you guys calling Wire.begin() to initialize I2C before calling tcaselect(). That could be your problem.
Here's my test code:
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BNO055.h>
#include <utility/imumaths.h>
/* select I2C channel using TCA9548A multiplexer */
void tcaselect(uint8_t channel)
Serial.print("I2C Channel: "); Serial.println(channel);
Wire.beginTransmission(0x70);
Wire.write(1 << channel);
Wire.endTransmission();
Adafruit_BNO055 bno = Adafruit_BNO055(55);
void displaySensorDetails(void)
sensor_t sensor;
bno.getSensor(&sensor);
Serial.println("------------------------------------");
Serial.print ("Sensor: "); Serial.println(sensor.name);
Serial.print ("Driver Ver: "); Serial.println(sensor.version);
Serial.print ("Unique ID: "); Serial.println(sensor.sensor_id);
Serial.print ("Max Value: "); Serial.print(sensor.max_value); Serial.println(" xxx");
Serial.print ("Min Value: "); Serial.print(sensor.min_value); Serial.println(" xxx");
Serial.print ("Resolution: "); Serial.print(sensor.resolution); Serial.println(" xxx");
Serial.println("");
delay(500);
void setup(void)
Serial.begin(115200);
Serial.println(""); Serial.println("Orientation Sensor Test"); Serial.println("");
Wire.begin();
uint8_t ch;
for (ch=0; ch<2; ch++) // multiple I2C devices
tcaselect(ch);
/* Initialise the sensor */
if(!bno.begin())
/* There was a problem detecting the BNO055 ... check your connections */
Serial.print("Ooops, no BNO055 detected ... Check your wiring or I2C ADDR!");
while(1);
delay(1000);
tcaselect(ch);
/* Display some basic information on this sensor */
displaySensorDetails();
void loop(void)
delay(100);
uint8_t ch;
tcaselect(ch);
/* Get a new sensor event */
sensors_event_t event;
bno.getEvent(&event);
imu::Quaternion q = bno.getQuat();
float temp = q.x(); q.x() = q.y(); q.y() = temp; q.z() = -q.z(); // fly.c convention
q.normalize();
#if 0 // use broken BNO055 euler
/* The processing sketch expects data as roll, pitch, heading */
Serial.print(F("Orientation: "));
Serial.print( event.orientation.x); // heading
Serial.print(F(" "));
Serial.print(-event.orientation.y); // roll
Serial.print(-event.orientation.z); // pitch
Serial.println(F(""));
#else
/* Convert quaternion to Euler, because BNO055 Euler data is broken */
imu::Vector<3> euler;
/* Adafruit's confusing x,y,z names are actually axis Z,Y,X rotations heading,roll,pitch */
euler.x() = 180/M_PI * atan2(q.w()*q.z() + q.x()*q.y(), 0.5 - q.y()*q.y() - q.z()*q.z()); // heading
euler.y() = 180/M_PI * atan2(q.w()*q.x() + q.y()*q.z(), 0.5 - q.x()*q.x() - q.y()*q.y()); // roll
euler.z() = 180/M_PI * asin(2 * (q.w()*q.y() - q.x()*q.z())); // pitch
Serial.print(euler.x()); // heading, nose-right is positive, z-axis points up
Serial.print(euler.y()); // roll, rightwing-up is positive, y-axis points forward
Serial.print(euler.z()); // pitch, nose-down is positive, x-axis points right
#endif
/* send quaternion */
Serial.print(F("Quaternion: "));
Serial.print(q.w(), 4);
Serial.print(q.x(), 4);
Serial.print(q.y(), 4);
Serial.print(q.z(), 4);
/* Also send calibration data for each sensor. */
uint8_t sys, gyro, accel, mag = 0;
bno.getCalibration(&sys, &gyro, &accel, &mag);
Serial.print(F("Calibration: "));
Serial.print(sys, DEC);
Serial.print(gyro, DEC);
Serial.print(accel, DEC);
Serial.println(mag, DEC);
