BLE Friend Hardware Reset
- chrismolloy
Re: BLE Friend Hardware Reset
Where are you adafruit support mike?
- chrismolloy
My last post is unanswered and is 24 hours old...
- chrismolloy
Re: Ble friend "couldn't factory reset"
I seem to have two threads going on the same subject. can we use the other one?
I am using the arduino environment and the monitor
- chrismolloy
I was able to reset the module using the DFU pin. the factory reset pad on the back of the board does not reset the board.
Still "unable to factory reset" when running the factory reset sketch.
ble.begin(VERBOSE_MODE) results in an "OK" indicating that there was a successful communication to the board.
just the reset is not working.
here is the output of the factory reset sketch:
Adafruit Factory Reset Example
Initialising the Bluefruit LE module: OK!
Performing a factory reset:
AT+FACTORYRESET
<- Couldn't factory reset
AT+FACTORYRESET
About the FCR pad on the back of the BLE module: are you connecting that to GND before connecting the 5v pin, and holding it low while the board powers up? That's how that signal behaves.
Only connecting power and ground while doing a factory reset is fine.
About the factory reset sketch failing, what voltage do you see on the MOD pin while the sketch is running?
- chrismolloy
Here is the state of the MOD pin. I connected it to D7 and read it just Prior to the factory reset command.
Mode Pin State: 1 <<------------------------------------------------------------
AT+FACTORYRESET
<- ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
AT+FACTORYRESET
- chrismolloy
AT+FACTORYRESET
<- ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ CANT FIGURE OUT WHERE THIS IS COMING FROM. TRIED TRACING THE CODE IN THE LIBRARIES, BUT CAN NOT FIND ANY INSTANCE OF
Serial.print
AT+FACTORYRESET
Serial.print
I asked for the voltage on the M0 pin, not the output from the serial monitor. There are some hardware issues I want to rule out.
- adafruit_support_rick
Can you try a different set of pins on your redboard? You may have a bad pin.
- chrismolloy
using pins 2 thru 7
AT+FACTORYRESET
AT+FACTORYRESET
- chrismolloy
I get exactly the same response with the ble friend removed from the circuit!
- chrismolloy
to be clear, I unplugged the module from the circuit and the software still reported OK for ble.begin()
- chrismolloy
I tried a genuine UNO instead of the redboard with the same results. I also downgraded the library to the previous 2 versions with no change.
hooked it up with an FTDI and everything works perfectly.
I will try communicating from the arduino software serial back thru the FTDI to a terminal program to confirm the software serial is working.
Looking at the library, I think there's a bug in begin. It looks like it will always return OK.
So, are you using the correct constructor in your sketch? You're connected with software spi? Are you using the software SPI constructor?
