I am trying to burn the firmware onto a blank ATtiny85V-10PU purchased from mouser and am having trouble and would greatly appreciate it if you could tell me where I am going wrong.
I removed resistor R1 from the TV-B-Gone board.
I am using a Pocket AVR Programmer from https://www.sparkfun.com/products/9825
I downloaded the drivers from https://github.com/sparkfun/Pocket_AVR_ ... er/Drivers and used the Zadig Driver with the libusb-win32 driver and named the programmer "USBtiny".
I downloaded the firmware v1.2 from https://learn.adafruit.com/tv-b-gone-kit/download
I downloaded WinAVR from http://sourceforge.net/projects/winavr/ ... urce=files
I instilled WinAVR and opened the MAKEFILE using the Programmer's Notepad and on line 99 I verified it said "usbtiny" which it did on line 104 I changed the "-B" to a "-F" I have no idea what that did but I read somewhere I had to in order for it to work... with it as a "-B" I get an error when trying to upload and with the "-F" I don't get the error.
I didn't change the com port because my program is not showing up as a com port...???
I then clicked "Tools/[WinAVR] Make All" which posted the below reply and seemed to work.
Make All
> "make.exe" all
-------- begin --------
avr-gcc (WinAVR 20100110) 4.3.3
Copyright (C) 2008 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or F;TNESS FOR A PARTICULAR PURPOSE.
Size before:
tvbgone.elf :
section size addr
.text 7934 0
.data 2 8388704
.bss 4 8388706
.debug_aranges 32 0
.debug_pubnames 7431 0
.debug_info 9520 0
.debug_abbrev 656 0
.debug_line 1285 0
.debug_frame 144 0
.debug_str 6167 0
.debug_loc 799 0
Total 33974
Size after:
tvbgone.elf :
section size addr
.text 7934 0
.data 2 8388704
.bss 4 8388706
.debug_aranges 32 0
.debug_info 9520 0
.debug_abbrev 656 0
.debug_line 1285 0
.debug_frame 144 0
.debug_str 6167 0
.debug_loc 799 0
Total 33974
Errors: none
-------- end --------
> Process Exit Code: 0
> Time Taken: 00:03
> "make.exe" program
avrdude -p attiny85 -P com3 -c usbtiny -F 1 -U flash:w:tvbgone.hex
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e930b
avrdude: NOTE: FLASH memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "tvbgone.hex"
avrdude: input file tvbgone.hex auto detected as Intel Hex
avrdude: writing flash (7936 bytes):
Writing | ################################################## | 100% 23.20s
avrdude: 7936 bytes of flash written
avrdude: verifying flash memory against tvbgone.hex:
avrdude: load data flash data from input file tvbgone.hex:
avrdude: input file tvbgone.hex contains 7936 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 11.91s
avrdude: verifying ...
avrdude: 7936 bytes of flash verified
avrdude done. Thank you.
> Time Taken: 00:35
I tried the same procedure with Make All and Program with the main.c file as well.
If I then try the TV-B-Gone with R1-Hooked back up (or put that chip in my other TV-B-Gone kit) it doesn't turn off TVs and the green light flashes a few times but steady and with a long delay not like the flashing that happens with the Adafruit chip. If I put the Adafruit chip back into either of the kits it works fine.
I have verified that the markings on both the Adafruit chip and the one I got from Mouser are identical.
What am I doing wrong? Am I supposed to load some other libraries somehow? Is there a tutorial anywhere on how to flash a blank chip with this firmware?
I admittedly have no idea what I am doing, but was able to successfully flash a controller before with the same programmer.
If it is not listed above I probably didn't do it. Can anyone please help?
