additional codes, script
by razer on Sat Dec 12, 2009 7:53 am
Hi!
I recently built a TV-B-Gone and would like to add some IR-codes to the firmware, so that I am also able to turn off projectors. My problem is, that all the codes I can find on the Web are written for universal remote controls. I saw on the TV-B-Gone page that there is a perl script to convert these codes, but couldn't find it in the download section or somewhere else on the Web.
Do you know a better website as http://www.remotecentral.com/cgi-bin/codes to find new IR-Codes that can be used for the TV-B-Gone?
Is there a way to get the perl script or another script to convert the codes?
Greetings from Switzerland
razer
Re: additional codes, script
by adafruit on Sat Dec 12, 2009 12:10 pm
the perl script is in the firmware download zip
by jalisse on Mon Feb 01, 2010 6:05 pm
@adafruit which script is in the download zip? Can I use parsegen3.pl for convert the codes from http://www.remotecentral.com to TVBGone? Can you explain to me with an example?
Thank you
jalisse
by adafruit on Mon Feb 01, 2010 6:54 pm
you can see the code captures in the download zip
then read this
http://www.ladyada.net/make/tvbgone/design.html
by jalisse on Tue Feb 02, 2010 4:23 am
Thank you adafruit but I don't understand as convert the code of remotecentral.com for TV-B-Gone. Can you explain with an example?
There are also the codes of lirc http://lirc.sourceforge.net/remotes/. Is it possible to convert?
jalisse
by adafruit on Tue Feb 02, 2010 2:05 pm
not sure, we used our own datacapture, you could probably write a perl script like ours to do the conversion or do it by hand like we show
by scanboostar on Sun Feb 19, 2012 4:06 pm
Can you please explain how you did the data capture of the universal remote that resulted in the .dat files?
The parsegen3.pl operates on the .dat files (from the firmware archive) to generate the compressed data in structs.
I ran rawirdecode.pde on an Arduino that generates the IRsignal array uncompressed.
Is there an of the shelf solution available to capture the .dat files in the same structure on the Arduino (or is maybe it not fast enough)?
Best regards,
Hessel.
scanboostar
by berlusconi on Tue Mar 20, 2012 11:32 am
I found this on the web ... any idea how it works? It says "Just input the Pronto IR Codes and my program will spit out the corresponding codes for TV-B-Gone"... I wonder if i should place those two php files on a web server?
https://github.com/davidawang/TV-B-Gone-IR-Generator
berlusconi
