My PIC-based TV-B-Gone (design attached)
Re: My PIC-based TV-B-Gone (design attached)
by Kayvon on Sat Feb 25, 2012 12:27 am
I no longer have Eagle installed, but I believe this is the file you requested. Let me know if it gives you problems and I'll figure it out.
PIC_TV-B-Gone.zip
Eagle schematic
(59.67 KiB) Downloaded 344 times
Kayvon
by caitsith2 on Sat Feb 25, 2012 2:28 am
That was exactly the file needed. Looks like you did some revisions some time after the actual release of the design.
I have a code base, that in combination with a 24F16KA101, would allow for both the North American code database, and the European code database to co-exist, and the method to run them, would also make use of the second button. The way it would work, is that one region would be the default one to run, when just the reset button is pressed, and running the other, is a matter of holding the stop button, while pushing reset, then releasing the stop button. (Pushing the stop button a second time, stops the sequence playback as usual.)
caitsith2
by pato5000 on Sat Apr 14, 2012 5:44 pm
Hi, first of all, thank you for sharing your design!!
I was wondering if the code could be ported to another PIC more "affordable". I mean another pic not as new as this one that could be burned with a standard programmer..
Thanks!!
pato5000
by exapod on Wed Apr 18, 2012 11:35 am
i have a working code for the pic18f2550 or similar that works with the internal oscillator and can send both the european and american code.
Contact me if you want it.
exapod
by jibbomussi on Thu Oct 25, 2012 2:31 am
I’ve been reading it for a while and thanks for the post.
http://hamariweb.com/pakistan-tv-channels/ptv-news.aspx
jibbomussi
by ColdKeyboard on Mon Jun 10, 2013 5:10 pm
exapod wrote:i have a working code for the pic18f2550 or similar that works with the internal oscillator and can send both the european and american code.
Could you please share it with the rest of us?
Thank you! :)
ColdKeyboard
by exapod on Sun Jul 14, 2013 6:12 am
Here it is the code for the pic18f2553..
v00 NON toccare.zip
(82.96 KiB) Downloaded 169 times
exapod
by ColdKeyboard on Sun Jul 14, 2013 9:05 am
Thank you very very much! :)
I'll try to get my hands on 18F2553 and test it.
Cheers!
ColdKeyboard
by ColdKeyboard on Wed Jul 31, 2013 3:58 am
I've tried to compile this code for 18F2555 and compiling went ok, I burned the HEX file and when I watch IC LEDS (with my phone camera) they flash very briefly and It takes about 1:45 sec to loop trough all the codes.
However when I try to turn of any TV...nothing happens :\
Can anyone please help me on what I'm doing wrong here? :\
ColdKeyboard
by exapod on Fri Aug 02, 2013 4:50 am
If you are in the usa you have to use this:
prova us.zip
(114.09 KiB) Downloaded 88 times
exapod
by ColdKeyboard on Fri Aug 02, 2013 5:56 am
I'm from Europe.
Do you have any other idea why it isn't working for me?
It takes about 1 minute and 45 seconds to loop trough all of the codes (EU), and LEDs flash very briefly, I guess that's ok?
I tried it on 10-20 TV and none of them turned off :\
ColdKeyboard
by exapod on Fri Aug 02, 2013 7:38 am
Are you using a correct wavelenght ir led?
Where do you connect it?
exapod
by ColdKeyboard on Fri Aug 02, 2013 3:25 pm
I was able to get my hands on LTE-5208 IR LEDs, in datasheet it says that wavelength is 940nm and forward voltage of 1.2V.
I connected 4 of these with 100ohm resistor to base of NPN transistor on port RC0 (PIN11 of PIC18F2550)
Here is my schematic http://imgur.com/pwRxPWN
ColdKeyboard
by exapod on Fri Aug 02, 2013 6:32 pm
You have to collect the ir led on the RC2 pin 13 of the pic.
The RC0 is the userled and it is a non infrared led that blinks when the PIC sends a code.
exapod
by ColdKeyboard on Thu Aug 08, 2013 2:42 pm
Darn, how didn't I notice that :S I feel so stupid about it now.
I will re-wire the PCB and let you know if it works :)
ColdKeyboard
