I just received 2 TV-B-Gone kits, and neither pass the initial LED flash test. I tried swapping the chips, with no success.
Here are the checks I've done, using new alkaline batteries:
Checked the switch - pressing the switch grounds pin 1
Checked that Vcc was at pins 4 to 8
Checked the green LED by grounding pin 5 (with the chip removed)
Checked the IR LEDs and driver circuitry by grounding pin 5 through a 10 K resistor (with the chip removed)
All the above tests check out. The LED flash test failed before I finished populating the boards - only the called-for parts were on the board at the time.
Is it possible that unprogrammed chips were supplied with the kits?
Thanks,
Bill
Green LED doesn't flash
Re: Green LED doesn't flash
we think some kits earlier this month got bad chips, email support@adafruit to get new ones!
- feralbill
Thanks for the quick reply! BTW, I noticed that R1 and R2 are inverted on the schematic http://www.ladyada.net/images/tvbgone/t ... 2schem.png
Thanks again,
Bill
Thanks again,
Bill
