I purchased a TV-B-Gone Kit to assemble with my son Ross. We made it to the micro test step, but the LED does not flash. Here is what we have done to date:
• Used good ESD practices.
• Inspected for open traces, good solder joints, and there are no shorts under high magnification.
• Tested the LED (works fine, normal voltage drop)
• Checked to assure power is at the micro with new alkaline batteries.
I’m not sure what else to do. Is there a chance that the micro is un-programmed? Is there any state of the micro that would yield an un-flashing LED?
I'll try a few things listed in the forum here too.
Thanks in advanced for any help you can provide.
Green LED does not flash
Re: Green LED does not flash
Update:
- Removed battery.
- Removed micro.
- Used Fluke meter in mA current mode to short pins 4&7. LED lights!
Obvioulsy a micro issue?
Comments welcome.
Bob
- Removed battery.
- Removed micro.
Comments welcome.
Bob
hi bob,rbc12363 wrote:Update:
- Removed battery.
- Removed micro.
Comments welcome.
Bob
thanks for posting this up - that's correct, it does look like a micro issue, we'll send a new one out to you and follow up via email.
cheers,
Got new micro, works perfectly!
Thanks for the help and prompt replies...
Bob
Bob
