Tv turns on then off.
When I use the kit to turn the TV on it turns off right away is normal or do I have a problem?
Re: Tv turns on then off.
this can happen if the TV responds to two different codes, just put it in your pocket when the target TV turns off
You can also switch out to a battery holder that has a SDPT switch on it. I upgraded the standard socket to a 3AA with SPDT on it. Helps preserve battery life and keeps the transistors from warming up because of constant use to turn off a single set or a few sets.esmith1390 wrote:When I use the kit to turn the TV on it turns off right away is normal or do I have a problem?
