Faulty Microcontroller - the green LED does not flash
Meztek
Post by Meztek »
As described here, the green LED does not flash. I have carefully assembled the kit up to the IC test, but after putting batteries in and pressing the button, the LED does not flash.
I have checked and rechecked my batteries. I have verified that all other components are working and have been soldered correctly. I have double checked that there are no solder bridges.
After reading this post for help, I have concluded that I have the same problem.
I've removed the battery and the microcontroller and replaced them and it still doesn't work. I have also tested the green LED and it works fine. It looks like a microcontroller issue and I need a replacement.
Any advice is appreciated.
Re: Faulty Microcontroller - the green LED does not flash
Post by adafruit »
when did you get the kit?
Meztek
Post by Meztek »
I got it December 2010.
Post by adafruit »
oh ok, that was a while ago so it wasnt clear. sure lets try a new micro. email [email protected] with a link to this post asking for a new tvgone micro
Return to “TV-B-Gone Kit”
