Doubt about the pnp transistor
by exapod on Wed Feb 08, 2012 11:55 am
If you use a pnp transistor for switch the npn that drives the leds is the pwm signal inverted? i mean if the pwm of the uc pin is high for 20us the led will be off for 20 us or i am wrong?
exapod
Re: Doubt about the pnp transistor
by stephanie on Wed Feb 08, 2012 2:29 pm
You are correct, when pin 5 is high, the IR leds are off, and when pin 5 is low, the IR leds are on.
stephanie
by exapod on Thu Feb 09, 2012 7:55 am
So if i use the v1,2 software but control only one led with a npn it will not work??
exapod
by stephanie on Thu Feb 09, 2012 8:42 am
If you want to do that then you'd have to modify the software to invert the signal on that pin. It's not too difficult, just changing a few lines in the main file.
I actually had to do this on my most-recent TV-B-Gone build, not for the IR LEDs but for the visible LED as my build had the visible LED wired to ground instead of Vcc.
stephanie
by exapod on Thu Feb 09, 2012 5:14 pm
Thank you for the help.
exapod
