TVbGone doesn't work always
by ks3556 on Sat Sep 01, 2012 3:41 pm
Hello everyone, ive got a problem with my TVbGone Kit.
The Problem is, i doesn't work all the time.
When i put new batteries into the holder, it works very good for about 2-3 times, but the following 'rounds' the green led blinks only for 3 seconds or so. :(
When i waited some minutes or pushed the button very long, it worked several times again. :?:
Please dont tell me "aaaww your batteries dont have enough power, use new ones".. i've already tried that :) And the Voltmeter says the batteries are Full.
It doesn't look like there's a short circuit somewhere, so i think it has to do with the IC, maybe?
Please Help Me :D
Have a nice day
ks3556
Re: TVbGone doesn't work always
by richms on Sat Sep 01, 2012 10:11 pm
What does the battery voltage do when you are transmitting.
I had similar issues when I put in some non alkaline cheap ones, they just sagged too much under load.
richms
by adafruit_support_bill on Sun Sep 02, 2012 6:06 am
If you post photos of the front & back of the board we can check for assembly issues. But from the symptoms you report, as suggested by richms, batteries are the most likely suspect.
If it were a defective IC, changing the batteries wouldn't help.
