Memorial day is 05/25/2015 – Orders will ship out on May 26th. There will not be any deliveries or shipping on Monday. Any order placed after 11am ET on Friday May 22nd will not start to ship out until Tuesday May 26th.
How to check the components of the soldered kit?
by Jens on Sat Sep 29, 2012 3:09 pm
I just finalize my second TV-B-Gone kit. When I pressed the button (or insert the battery) the green LED is only blinking few times (not flashing like a code signal).
I checked the processor (with the first kit) - it works.
First the infrared-LED slowly blinked (check with digicam) - but now nothing just the green.
The ceramic oscillator may be faulty?
How can I check all electronic components with my e.g. multimeter?
Thanks.
Jens
Re: How to check the components of the soldered kit?
by adafruit_support_bill on Sat Sep 29, 2012 7:06 pm
Most problems come down to soldering. If you post clear photos of the front & back of the board we will take a look.
by Jens on Sun Sep 30, 2012 7:30 am
Dear Support,
adafruit_support wrote:Most problems come down to soldering. If you post clear photos of the front & back of the board we will take a look.
Hopefully clear enough:
Jens_TVBG_back pseudo3D.GIF (267.33 KiB) Viewed 2044 times
Jens
by adafruit_support_bill on Sun Sep 30, 2012 5:38 pm
A couple suspicious joints on the ICSP header, but that shouldn't affect normal operation.
Are you using a fresh battery? That symptom is consistent with a weak battery.
by Jens on Tue Oct 02, 2012 2:22 pm
Yes, the batteries are fresh. I checked it with an other TV-B-Gone.
And, I re-soldered (melded) all pins.
So, back to my first question. How can I check the single elements?
A link forward to a wiki or - old school - a book will be fine.
Jens
by adafruit_support_bill on Tue Oct 02, 2012 3:18 pm
It is difficult to test individual components once they are soldered into a circuit. What test equipment do you have access to? You can verify the operation of the oscillator with an oscilloscope or a frequency counter. With a multimeter, you can check that the battery voltage stays relatively constant. If the voltage sags significantly during operation, that would indicate a short or damaged component somewhere. Those can often be located by feeling for what is getting hot.
by adafruit_support_rick on Tue Oct 02, 2012 3:47 pm
I suggest double checking that you installed the right transistor at Q5. The 5 transistors all look alike, but Q5 is a very different part. Q1, Q2, Q3, and Q4 are NPN transistors and should all have the same markings, while Q5 is a PNP, and will have different marking.
by Jens on Mon Oct 08, 2012 2:28 pm
Thanks to driverblock,
Yes of cause I double checked before I posted. Every component is at there right place.
4 equal transistor "PN2222A" close to the LED and the single transistor "PN2907" at the single place.
Thanks to adafuit_support,
Yes I have only a multimeter. I checked the lack of voltage, it fall only from 5V (4 x 1.2V AAA accu) to 4,8V while I pressed the reset button.
So, my next steps are to re-solder single components and solder it in an existing (working) TV-B-Gone or give google a try.
Jens
