Jasonx: Grab the gerber files from
http://BANNED.net/projects/tvbgone/t ... erbers.zip. These should be complete.
*.cmp = Top Copper
*.sol = Bottom Copper
*.stc = Top Soldermask
*.sts = Bottom Soldermask
*.plc = Top Silkscreen
*.pls = Bottom Silkscreen. (most likely not required.)
*.drd = NC Drill File. Tool and Aperture listings fully included, no seperate tool file required.
*.dim = Board Outline. (Some PCB manufactures require this file, others don't. Having this file, means I don't have to worry about going back to generate it, if the PCB manufacture I choose to use, requires this file to define the board outline.)
(Your X/Y board dimensions are 2.44 Inches by 1.7 Inches. (2440 mils by 1700 mils) or (61.976mm by 43.180mm))
Oh yeah, I will be going on a major power trip, when I decide to make this EHP Pro / EHP Boost board set, when money permits. Actually, if you have just the EHP board, The EHP Boost can be added to that design as well. (It would just be 8 IR LEDs on the normal EHP board, along with 4xAA power supply for that board, and Boost Board, with 2x3xAA for the boost power supply. (The boost board does not draw any existing power whatsoever from the main board.)
