IR widget from top side
And from bottom side
I hit that one little snag, when I finally got my PCB. THe holes, where the QSE157 was supposed to go, were too small. I did work around the issue though, by surface mounting it. (2 pins on top side, 1 on bottom.) (If I order another of the PCB, I will make sure to correct that error first.)
Also, Just before I got that PCB and put it together, I made an Arduino Diecimila version. Despite the C code written, because I know how to use an AVR simulator to trace things, the timing is exactly 100 microseconds between each byte sent.
#define tx_port PORTD
#define tx_bit 1
#define mode1_port PINB
#define mode1_bit 7
#define mode2_port PINB
#define mode2_bit 5
#define status_led_port PORTB
#define status_led_bit 0
#define ir_demod_port PIND
#define ir_demod_pin 2
void setup()
DDRB = B01011111;
PORTB = B00000000;
DDRD = B00101010;
PORTD = B00110000;
TCCR0A = 0;
TCCR0B = (1<<CS02)|(1<<CS01);
TCCR1A = 0;
TCCR1C = 0;
TCCR1B = (1<<CS11)|(1<<CS10);
Serial.begin(115200);
uint16_t time_save;
void report_time(int period)
uint16_t temp = TCNT1L | (TCNT1H << 8);
temp-=time_save;
time_save+=temp;
temp>>=1;
temp|=period;
//Serial.print(temp&0xFF,BYTE);
//Serial.print(temp>>8,BYTE);
Serial.println(temp,DEC);
void loop()
int tx_data;
int prev_count;
int temp;
// cli();
while(Serial.available()==0); //Wait for host to decide what mode to execute.
temp = Serial.read();
if((temp==0)||(temp=='0'))
while(1) //Count Mode
Serial.read();
cli();
//Count_First
tx_data = TCNT0;
do
temp = TCNT0;
while (temp==tx_data);
digitalWrite(8,HIGH);
//do
while(1) {
//cli();
prev_count = tx_data;
Serial.print(tx_data,BYTE);
//delayMicroseconds(100);
delayMicroseconds(93); //Make this loop exactly 100 microseconds.
__asm__ __volatile__ (
"nop\n\t" //When I traced, the loop was exactly 99.5 microseconds.
"nop\n\t" //7 nops, to make the loop 99.9375 microseconds long.
"nop\n\t"
"nop\n\t"
"nop\n\t"
"nop\n\t"
"nop\n\t"
tx_data = TCNT0;
if(tx_data==prev_count)
"nop\n\t" //And this nop makes the loop 100 microseconds long,
//when there is no change in counts.
digitalWrite(8,LOW);
else
{ //The branch to here makes 100 microseconds
//when the count has changed.
//sei();
}// while(Serial.available()==0);
Serial.read();
else //Time mode
while(1)
while(digitalRead(4));
report_time(0x0000);
while(!digitalRead(4));
report_time(0x8000);
