I'm trying to assemble a tv-b-gone in a breadboard and it is not working. I'm using the v1.2 firmware and hardware. After all the work the green led blinks every 3 seconds and the IR leds blinks randomly. I don't know what causes that. Anyone can help me?
Sorry for my bad english, I'm from Brazil.
Green Led Blinking and Tv-b-gone not working
- adafruit_support_bill
Re: Green Led Blinking and Tv-b-gone not working
Check all your breadboard connections and make sure you have adequate power. The IR leds draw a lot of current and a voltage drop could cause the processor to reset.
- senra
I checked the connections twice and I'm using now a 5v power supply ( before I was using 2 AA batteries). The led still blinking every 3 seconds but now it is blinking brigther. I followed the instructables page to burn the firmware in to a blank attiny85 using an Arduino Uno as ISP, can it be the problem?
Thanks for the fast answer.
Try disconnecting all but one of the IR leds.
- senra
I've disconnected everything except one of the IR leds but the problem still happening. The IR led still blinking slowly, I've tested it in my Tv and I couldn't turn it on/off.
Is it still blinking every 3 seconds, or did anything change?the problem still happening.
- senra
Still blinking every 3 seconds. I suspect that I don't know how to burn the firmware in to the attiny85 20pu.
I would expect no blink at all if the chip were not programmed. If you post a photo of your setup we can try to spot the problem.
