Long Range LEDs not working.
- IMisiak
Hi, I built my TV B Gone kit and everything was working fine until about a day after I completed it and I noticed that the Long range blue LEDs were no longer firing. Everything else on the board works and it still turns off TVs, but I would like for everything to work. Thanks, Ian
- IMisiak
Re: Long Range LEDs not working.
Update:
I tested the contacts and leds with a multimeter and the current is making it through the diode and is similar to the current running through the working diodes. The leds continue to not fire despite the current running through them.
- adafruit_support_bill
Hmmm. What are you using to power the TVBGone?
- IMisiak
The standard battery tray and 2 fresh AA batteries.
- Franklin97355
Could you post clear, detailed pictures of both sides of your board showing any soldering you have done and the connections to it?
- IMisiak
Hi, hopefully this is what you needed.
Please contact [email protected] with a link to this thread and request replacement long-range leds for your TVBGone.
