Alright, now my for loop doesn't work...here's the error:
Arduino: 1.6.5 (Windows 7), Board: "ATtiny, ATtiny45, 1 MHz (internal)"
main.c:82: error: variable 'NApowerCodes' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
extern const PGM_P *N ApowerCodes[] PROGMEM; (Adafruit doesn't allow me to type the letters N and A combines, so there's a space)
main.c:83: error: variable 'EUpowerCodes' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
extern const PGM_P *EUpowerCodes[] PROGMEM;
main.c: In function 'main':
main.c:318: error: 'for' loop initial declarations are only allowed in C99 mode
for (uint8_t k=0; k<numpairs; k++) {
main.c:318:7: note: use option -std=c99 or -std=gnu99 to compile your code
variable 'N ApowerCodes' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
en abled in File > Preferences.
And here's my code, too, for the main.c file. It doesn't allow me to type the letters N and A together, so they have spaces. :/
TV-B-Gone Firmware version 1.2
for use with ATtiny85v and v1.2 hardware
(c) Mitch Altman + Limor Fried 2009
Last edits, August 16 2009
With some code from:
Kevin Timmerman & Damien Good 7-Dec-07
Distributed under Creative Commons 2.5 -- Attib & Share Alike
This is the 'universal' code designed for v1.2 - it will select EU or N A
depending on a pulldown resistor on pin B1 !
#include <avr/io.h> // this contains all the IO port definitions
#include <avr/eeprom.h>
#include <avr/sleep.h> // definitions for power-down modes
#include <avr/pgmspace.h> // definitions or keeping constants in program memory
#include <avr/wdt.h>
#include "main.h"
#include "util.h"
This project transmits a bunch of TV POWER codes, one right after the other,
with a pause in between each. (To have a visible indication that it is
transmitting, it also pulses a visible LED once each time a POWER code is
transmitted.) That is all TV-B-Gone does. The tricky part of TV-B-Gone
was collecting all of the POWER codes, and getting rid of the duplicates and
near-duplicates (because if there is a duplicate, then one POWER code will
turn a TV off, and the duplicate will turn it on again (which we certainly
do not want). I have compiled the most popular codes with the
duplicates eliminated, both for North America (which is the same as Asia, as
far as POWER codes are concerned -- even though much of Asia USES PAL video)
and for Europe (which works for Australia, New Zealand, the Middle East, and
other parts of the world that use PAL video).
Before creating a TV-B-Gone Kit, I originally started this project by hacking
the MiniPOV kit. This presents a limitation, based on the size of
the Atmel ATtiny2313 internal flash memory, which is 2KB. With 2KB we can only
fit about 7 POWER codes into the firmware's database of POWER codes. However,
the more codes the better! Which is why we chose the ATtiny85 for the
TV-B-Gone Kit.
This version of the firmware has the most popular 100+ POWER codes for
North America and 100+ POWER codes for Europe. You can select which region
to use by soldering a 10K pulldown resistor.
This project is a good example of how to use the AVR chip timers.
The hardware for this project is very simple:
ATtiny85 has 8 pins:
pin 1 RST + Button
pin 2 one pin of ceramic resonator MUST be 8.0 mhz
pin 3 other pin of ceramic resonator
pin 4 ground
pin 5 OC1A - IR emitters, through a '2907 PNP driver that connects
to 4 (or more!) PN2222A drivers, with 1000 ohm base resistor
and also connects to programming circuitry
pin 6 Region selector. Float for US, 10K pulldown for EU,
pin 7 PB0 - visible LED, and also connects to programming circuitry
pin 8 +3-5v DC (such as 2-4 AA batteries!)
See the schematic for more details.
This firmware requires using an 8.0MHz ceramic resonator
(since the internal oscillator may not be accurate enough).
IMPORTANT: to use the ceramic resonator, you must perform the following:
make burn-fuse_cr
extern const uint8_t num_N Acodes, num_EUcodes;
/* This function is the 'workhorse' of transmitting IR codes.
Given the on and off times, it turns on the PWM output on and off
to generate one 'pair' from a long code. Each code has ~50 pairs! */
void xmitCodeElement(uint16_t ontime, uint16_t offtime, uint8_t PWM_code )
// start Timer0 outputting the carrier frequency to IR emitters on and OC0A
// (PB0, pin 5)
TCNT0 = 0; // reset the timers so they are aligned
TIFR = 0; // clean out the timer flags
if(PWM_code) {
// 99% of codes are PWM codes, they are pulses of a carrier frequecy
// Usually the carrier is around 38KHz, and we generate that with PWM
// timer 0
TCCR0A =_BV(COM0A0) | _BV(WGM01); // set up timer 0
TCCR0B = _BV(CS00);
} else {
// However some codes dont use PWM in which case we just turn the IR
// LED on for the period of time.
PORTB &= ~_BV(IRLED);
// Now we wait, allowing the PWM hardware to pulse out the carrier
// frequency for the specified 'on' time
delay_ten_us(ontime);
// Now we have to turn it off so disable the PWM output
TCCR0A = 0;
TCCR0B = 0;
// And make sure that the IR LED is off too (since the PWM may have
// been stopped while the LED is on!)
PORTB |= _BV(IRLED); // turn off IR LED
// Now we wait for the specified 'off' time
delay_ten_us(offtime);
/* This is kind of a strange but very useful helper function
Because we are using compression, we index to the timer table
not with a full 8-bit byte (which is wasteful) but 2 or 3 bits.
Once code_ptr is set up to point to the right part of memory,
this function will let us read 'count' bits at a time which
it does by reading a byte into 'bits_r' and then buffering it. */
uint8_t bitsleft_r = 0;
uint8_t bits_r=0;
PGM_P code_ptr;
// we cant read more than 8 bits at a time so dont try!
uint8_t read_bits(uint8_t count)
uint8_t i;
uint8_t tmp=0;
// we need to read back count bytes
for (i=0; i<count; i++) {
// check if the 8-bit buffer we have has run out
if (bitsleft_r == 0) {
// in which case we read a new byte in
bits_r = pgm_read_byte(code_ptr++);
// and reset the buffer size (8 bites in a byte)
bitsleft_r = 8;
// remove one bit
bitsleft_r--;
// and shift it off of the end of 'bits_r'
tmp |= (((bits_r >> (bitsleft_r)) & 1) << (count-1-i));
// return the selected bits in the LSB part of tmp
return tmp;
The C compiler creates code that will transfer all constants into RAM when
the microcontroller resets. Since this firmware has a table (powerCodes)
that is too large to transfer into RAM, the C compiler needs to be told to
keep it in program memory space. This is accomplished by the macro PROGMEM
(this is used in the definition for powerCodes). Since the C compiler assumes
that constants are in RAM, rather than in program memory, when accessing
powerCodes, we need to use the pgm_read_word() and pgm_read_byte macros, and
we need to use powerCodes as an address. This is done with PGM_P, defined
below.
For example, when we start a new powerCode, we first point to it with the
following statement:
PGM_P thecode_p = pgm_read_word(powerCodes+i);
The next read from the powerCode is a byte that indicates the carrier
frequency, read as follows:
const uint8_t freq = pgm_read_byte(code_ptr++);
After that is a byte that tells us how many 'onTime/offTime' pairs we have:
const uint8_t numpairs = pgm_read_byte(code_ptr++);
The next byte tells us the compression method. Since we are going to use a
timing table to keep track of how to pulse the LED, and the tables are
pretty short (usually only 4-8 entries), we can index into the table with only
2 to 4 bits. Once we know the bit-packing-size we can decode the pairs
const uint8_t bitcompression = pgm_read_byte(code_ptr++);
Subsequent reads from the powerCode are n bits (same as the packing size)
that index into another table in ROM that actually stores the on/off times
const PGM_P time_ptr = (PGM_P)pgm_read_word(code_ptr);
int main(void) {
uint16_t ontime, offtime;
uint8_t i,j, Loop;
uint8_t region = US; // by default our code is US
Loop = 0; // by default we are not going to loop
TCCR1 = 0; // Turn off PWM/freq gen, should be off already
TCCR0A = 0;
TCCR0B = 0;
i = MCUSR; // Save reset reason
MCUSR = 0; // clear watchdog flag
WDTCR = _BV(WDCE) | _BV(WDE); // enable WDT disable
WDTCR = 0; // disable WDT while we setup
DDRB = _BV(LED) | _BV(IRLED); // set the visible and IR LED pins to outputs
PORTB = _BV(LED) | // visible LED is off when pin is high
_BV(IRLED) | // IR LED is off when pin is high
_BV(REGIONSWITCH); // Turn on pullup on region switch pin
DEBUGP(putstring_nl("Hello!"));
// check the reset flags
if (i & _BV(BORF)) { // Brownout
// Flash out an error and go to sleep
flashslowLEDx(2);
tvbgone_sleep();
delay_ten_us(5000); // Let everything settle for a bit
// determine region
if (PINB & _BV(REGIONSWITCH)) {
region = US; // US
DEBUGP(putstring_nl("US"));
} else {
region = EU;
DEBUGP(putstring_nl("EU"));
// Tell the user what region we're in - 3 is US 4 is EU
quickflashLEDx(3+region);
// Starting execution loop
delay_ten_us(25000);
// turn on watchdog timer immediately, this protects against
// a 'stuck' system by resetting it
wdt_enable(WDTO_8S); // 1 second long timeout
// Indicate how big our database is
DEBUGP(putstring("\n\rN A Codesize: "); putnum_ud(num_N Acodes););
DEBUGP(putstring("\n\rEU Codesize: "); putnum_ud(num_EUcodes););
do { //Execute the code at least once. If Loop is on, execute forever.
// We may have different number of codes in either database
if (region == US) {
j = num_N Acodes;
} else {
j = num_EUcodes;
// for every POWER code in our collection
for(i=0 ; i < j; i++) {
// print out the code # we are about to transmit
DEBUGP(putstring("\n\r\n\rCode #: "); putnum_ud(i));
//To keep Watchdog from resetting in middle of code.
wdt_reset();
// point to next POWER code, from the right database
if (region == US) {
code_ptr = (PGM_P)pgm_read_word(N ApowerCodes+i);
} else {
code_ptr = (PGM_P)pgm_read_word(EUpowerCodes+i);
// print out the address in ROM memory we're reading
DEBUGP(putstring("\n\rAddr: "); putnum_uh(code_ptr));
// Read the carrier frequency from the first byte of code structure
// set OCR for Timer1 to output this POWER code's carrier frequency
OCR0A = freq;
// Print out the frequency of the carrier and the PWM settings
DEBUGP(putstring("\n\rOCR1: "); putnum_ud(freq););
DEBUGP(uint16_t x = (freq+1) * 2; putstring("\n\rFreq: "); putnum_ud(F_CPU/x););
// Get the number of pairs, the second byte from the code struct
DEBUGP(putstring("\n\rOn/off pairs: "); putnum_ud(numpairs));
// Get the number of bits we use to index into the timer table
// This is the third byte of the structure
DEBUGP(putstring("\n\rCompression: "); putnum_ud(bitcompression));
// Get pointer (address in memory) to pulse-times table
// The address is 16-bits (2 byte, 1 word)
code_ptr+=2;
// Transmit all codeElements for this POWER code
// (a codeElement is an onTime and an offTime)
// transmitting onTime means pulsing the IR emitters at the carrier
// frequency for the length of time specified in onTime
// transmitting offTime means no output from the IR emitters for the
// length of time specified in offTime
// print out all of the pulse pairs
uint8_t k;
for (k=0; k<numpairs; k++) {
uint8_t ti;
ti = (read_bits(bitcompression)) * 4;
// read the onTime and offTime from the program memory
ontime = pgm_read_word(time_ptr+ti);
offtime = pgm_read_word(time_ptr+ti+2);
DEBUGP(putstring("\n\rti = "); putnum_ud(ti>>2); putstring("\tPair = "); putnum_ud(ontime));
DEBUGP(putstring("\t"); putnum_ud(offtime));
// For EACH pair in this code....
uint8_t ti;
// Read the next 'n' bits as indicated by the compression variable
// The multiply by 4 because there are 2 timing numbers per pair
// and each timing number is one word long, so 4 bytes total!
ontime = pgm_read_word(time_ptr+ti); // read word 1 - ontime
offtime = pgm_read_word(time_ptr+ti+2); // read word 2 - offtime
// transmit this codeElement (ontime and offtime)
xmitCodeElement(ontime, offtime, (freq!=0));
//Flush remaining bits, so that next code starts
//with a fresh set of 8 bits.
bitsleft_r=0;
// delay 250 milliseconds before transmitting next POWER code
// visible indication that a code has been output.
quickflashLED();
} while (Loop == 1);
// We are done, no need for a watchdog timer anymore
wdt_disable();
// flash the visible LED on PB0 4 times to indicate that we're done
delay_ten_us(65500); // wait maxtime
quickflashLEDx(4);
tvbgone_sleep();
/****************************** SLEEP FUNCTIONS ********/
void tvbgone_sleep( void )
// Shut down everything and put the CPU to sleep
TCCR0A = 0; // turn off frequency generator (should be off already)
TCCR0B = 0; // turn off frequency generator (should be off already)
PORTB |= _BV(LED) | // turn off visible LED
wdt_disable(); // turn off the watchdog (since we want to sleep
delay_ten_us(1000); // wait 10 millisec
MCUCR = _BV(SM1) | _BV(SE); // power down mode, SE enables Sleep Modes
sleep_cpu(); // put CPU into Power Down Sleep Mode
/****************************** LED AND DELAY FUNCTIONS ********/
// This function delays the specified number of 10 microseconds
// it is 'hardcoded' and is calibrated by adjusting DELAY_CNT
// in main.h Unless you are changing the crystal from 8mhz, dont
// mess with this.
void delay_ten_us(uint16_t us) {
uint8_t timer;
while (us != 0) {
// for 8MHz we want to delay 80 cycles per 10 microseconds
// this code is tweaked to give about that amount.
for (timer=0; timer <= DELAY_CNT; timer++) {
NOP;
NOP;
NOP;
us--;
// This function quickly pulses the visible LED (connected to PB0, pin 5)
// This will indicate to the user that a code is being transmitted
void quickflashLED( void ) {
PORTB &= ~_BV(LED); // turn on visible LED at PB0 by pulling pin to ground
delay_ten_us(3000); // 30 millisec delay
PORTB |= _BV(LED); // turn off visible LED at PB0 by pulling pin to +3V
// This function just flashes the visible LED a couple times, used to
// tell the user what region is selected
void quickflashLEDx( uint8_t x ) {
quickflashLED();
while(--x) {
wdt_reset();
delay_ten_us(15000); // 150 millisec delay between flahes
quickflashLED();
wdt_reset(); // kick the dog
// This is like the above but way slower, used for when the tvbgone
// crashes and wants to warn the user
void flashslowLEDx( uint8_t num_blinks )
uint8_t i;
for(i=0;i<num_blinks;i++)
PORTB &= ~_BV(LED);
delay_ten_us(50000); // 500 millisec delay
PORTB |= _BV(LED);
