It seems that the problem is the proper Flow Control setting. I saw that some people had the same issue like here http://stackoverflow.com/questions/1391 ... ng-in-rxtx
But this solution does not work for me. If I set the FlowControl to None, than I get only a block icon on the display, indicating, that the serial connection has been established, but nothing else. If I set the FlowControl to RCTS_IN | RCTS_OUT, then I get the string bytes only on the display when I close the established connection.
Why is the data only send when I close the connection (Flushing the out stream did not help as well) ? What am I doing wrong with the Flow Controll settings?
This is the modified connect() method I'm using.
- Code: Select all
void connect(String portName) throws Exception {
CommPortIdentifier portIdentifier = CommPortIdentifier
.getPortIdentifier(portName);
if (portIdentifier.isCurrentlyOwned()) {
System.out.println("Error: Port is currently in use");
} else {
CommPort commPort = portIdentifier.open(this.getClass().getName(),
2000);
if (commPort instanceof SerialPort) {
SerialPort serialPort = (SerialPort) commPort;
serialPort.setSerialPortParams(115200, SerialPort.DATABITS_8,
SerialPort.STOPBITS_1, SerialPort.PARITY_NONE);
try {
serialPort.setFlowControlMode(
// SerialPort.FLOWCONTROL_NONE);
// OR
// If CTS/RTS is needed
//serialPort.setFlowControlMode(
SerialPort.FLOWCONTROL_RTSCTS_IN |
SerialPort.FLOWCONTROL_RTSCTS_OUT);
} catch (UnsupportedCommOperationException ex) {
System.err.println(ex.getMessage());
serialPort.setRTS(true);
in = serialPort.getInputStream();
out = serialPort.getOutputStream();
(new Thread(new SerialWriter(out))).start();
serialPort.addEventListener(new SerialReader(in, this));
serialPort.notifyOnDataAvailable(true);
} else {
System.out.println("Error: Only serial ports are to use!");
Thanks in advance for your time
