Hi Everyone,
I've just received my 16MB sound board and it's all working brilliantly, it really is an awesome product.
Just one question, is there anyway to get the board to play a sound file and then stop playing that file when another is triggered? I've been through the various modes by changing the file names and I don't seem to be able to get this function. The files I have to play are quite long and it would be really good if the user could switch between them without having to wait for the initial file to finish playing.
Thanks for any help with this
Cheers
Dicky
Soundboard Operation
- adafruit_support_rick
Re: Soundboard Operation
Nope - it won't do that.
- Funman1
If you got a micro-controller into the mix then, YES you could do that.
You could program the controller to hold a sound pin low until it detects a button press then send that pin high, and pull a different sound pin low.
If you configured the sound file so it was only played when the pin was held low that would work perfectly.
Depending on how many buttons and sounds you want, a pro trinket may work awesome and will keep the project on the cheap side.
- dicky
That's awesome, thanks for that, I'll definitely look into it
Cheers
Dicky
Cheers
Dicky
