Anybody here a Mac-o-phile and using AVRFuses (http://www.vonnieda.org/software/avrfuses)? I've killed one ATMega8515 and I since I have only one spare, I'd like to get this right.
All I'm trying to do is to use an 8MHz external crystal. In the current version of AVRFuses, there's no listing for an 8MHz crystal. There's listings for "Ext. RC Osc. 3.0 MHz - 8.0 MHz," with various startup times, and "Ext. RC Osc. 8.0 MHz - 12.0 MHz," with similar various startup times.
But those are *oscillators*, right? Not crystals. But even if that's right, should I pick the 3-8 or the 8-12? Default startup time is 6 CK + 12ms; should I use that?
Then there is a list of "Ext. Crystal/Resonator" for "Low Freq." "Medium Freq." or "High Freq." at various startup times, none of which are anything like 6 CK + 12ms. Is 8MHz low, medium or high?
Thoughts, comments, theories for this dunderhead would be appreciated.
Thanks so much.
\dmc
PS: Short of that, the AVRDude CL for changing from the default internal clock to an external crystal on an 8515 (and nothing else, right?) would be appreciated.
PPS: Lastly, assuming I set the fuses to "Ext. Clock; Start-up time: 6 CK + 64 ms" on the now-dead 8515, any thoughts on how to resurrect it?
