Reprogram ATMega16 signature bytes
For Adafruit customers who seek help with microcontrollers
pascor
Re: Reprogram ATMega16 signature bytes
Post by pascor »
Alan, you are exactly right. My basic stumbling block was that Avrdude misreports important information and its documentation is clearly misleading in its descriptions of the options. :roll: Oh well...
1) When Avrdude says that it can't talk with a chip then its report of the device signature is totally bogus and should have not been reported at all.
2) The "-b" option description makes no sense. I was mistaken when I assumed that this controlled the ISP serial programming clock frequency. It doesn't. The documentation gives no hint at what this option is really for.
3) The "-B" option actually controls all the serial programming interfaces' clocks. The Avrdude documentation fails to simply state this also controls the ISP programming clock rate.
I finally reprogrammed the clock control fuse byte to use the internal 8 MHz RC clock with this command :
avrdude.exe -B 20 -p atmega16 -P USB -c usbtiny -U lfuse:w:0xE4:m
This whole ordeal has been very painful due to the sheer quantity of misinformation and bad advice given. :x
Many thanks to all that have contributed who know what they're talking about ! :D
Return to “Microcontrollers”
