I'm looking into playing with the Atmega644 for its extra IO capabilities. I realize i should go with the sanguino bootloader since there isnt an adaboot or official arduion bootloader for it. My question is, i've searched both mouser and digi for the DIP version and i've got a lot of results with varying prices.
With that said, without having to really go into the spec sheets. Is there a "standard" one that is known to work? Look at these results! so many to choose from. As cheap as 7.50 to 8.36
I cant provide a direct link to digi since its a filtered search result, but there is the search parameter then just filter the 40-DIP
http://search.digikey.com/scripts/DkSea ... atmega644p
http://www.mouser.com/Search/Refine.asp ... =atmega644
ATMEGA644 versions, oh boy.. Any particular one?
- rizla420
- jftheoret
Re: ATMEGA644 versions, oh boy.. Any particular one?
I have a Sanguino board - it uses a ATMEGA644P-20PU
http://ca.mouser.com:80/ProductDetail/A ... PPwV66QU7m
You probably want one of the PDIP 40 packages (not the MLF or TQFP packages).
From what I understand (although I did not look through the individual datasheets) these variants (P, PA, A) relate to their power consumption and maximum clock frequency.
Here are some of the datasheets, if you care to look through them:
P version
http://www.atmel.com/dyn/resources/prod ... /8011S.pdf
A version
http://atmel.com/dyn/resources/prod_documents/8272S.pdf
PA version
http://www.atmel.com/dyn/resources/prod ... /8152S.pdf
P.S. Here's what I found on avrfreaks.net pertaining the P/A/PA
P version
A version
PA version
So you may be better off getting the cheaper 644A-PU.BTW, what's the difference between the P version and the non-P version?
P=Picopower
The Picopower AVRs are on a smaller fab with the dies shrunk and some additional power control stuff added. The 328 is the most recent member of the 48/88/168 family. They moved from 48/88/168 to 48P/88P/168P a while back and now those have moved to 48PA/88PA/168PA where "A" denotes no functional change but further power requirement reductions (a further die shrink presumably?). So maybe the latest "in stock" model of the 328 is actually 328PA. If not PA then certainly P.
- rizla420
Thanks alot, i just picked up a couple of the 20PU's. Time to make my own board for itjftheoret wrote:I have a Sanguino board - it uses a ATMEGA644P-20PU
P version
A version
PA version
P=Picopower
