PIC18F27J13, any tricks to RTC?
- zener
I am using the 18F27J13 again. This time trying out the PWM's (working) and the Real Time Clock (not working). I set the config register to enable it and enable the output (whatever that is) and then I read the HALFSEC bit to look for it transitioning. It does not appear to be working. I tried to set the oscillator to INTRC but the compiler said it doesn't recognize CONFIG3L. Strange. My 32KHz crystal does not appear to be oscillating.
- opossum
Re: PIC18F27J13, any tricks to RTC?
Typically you just have to enable TMR1 to use external xtal, and enable the RTCC.
T1CONbits.T1OSCEN = 1; // Enable 32.768 kHz osc
INTCONbits.GIE = 0; // Enable RTC writes (so clock can be set)
EECON2 = 0x55;
EECON2 = 0xAA;
RTCCFGbits.RTCWREN = 1;
RTCCFGbits.RTCEN = 1; // Enable RTC
void SetTime(void)
const uint8_t year = 0x10;
const uint8_t month = 0x11;
const uint8_t day = 0x11;
const uint8_t dow = 0x05;
const uint8_t hour = 0x23;
const uint8_t minute = 0x20;
const uint8_t second = 0x00;
RTCCFGbits.RTCPTR0 = 1;
RTCCFGbits.RTCPTR1 = 1;
RTCVALL = year; // Year
RTCVALH = 0; //
RTCVALL = day; // Day
RTCVALH = month; // Month
RTCVALL = hour; // Hour
RTCVALH = dow; // Week
RTCVALL = second; // Second
RTCVALH = minute; // Minute
void ShowTime(void)
uint8_t yr, mo, da, wk, hr, mn, se;
yr = RTCVALL;
da = RTCVALH;
da = RTCVALL;
mo = RTCVALH;
hr = RTCVALL;
wk = RTCVALH;
se = RTCVALL;
mn = RTCVALH;
printf((const rom char far *)"%02X.%02X.%02X %02X:%02x.%02x", yr, mo, da, hr, mn, se);
- zener
Thank you for the fast reply. I do have some questions though. Clearing INTCON bit 7 (GIE) disables interrupts. I don't see what that has to do with enabling writes to the RTC. Also, I am a little confused about the writes to EECON2, although I now see they are necessary. Also it is necessary to write individually to the bits of RTCCFG as you show. I was using:
RTCCFG = 0xEC; // Turn on and configure Real Time Clock
But that didn't work, even with the writes to EECON2 before it. Only your special code works. I am not using the GIE clear for now though.
I was able to get the oscillator going with the T1OSCEN bit! That is not so clear in the data sheet I think. The amplitude is about .7 volts PP at the crystal. I am guessing that is normal. My clock is running about 5% slow. I am using 22pF caps. Do you think that is too big? I know there is a cal register.
Also I would like to understand your second code box much better since I will likely need all that once I get the clock actually going. It appears you just read and write succesively to the same place but it increments the data automatically?
- opossum
Read section 17.2.7 (Write Lock), section 17.2.8 (Register Mapping) and note 3 on page 239.
If interrupts are not disabled, then the unlock may be interrupted and fail.
6 to 12 pf is typical for 32 kHz xtal. Some micros (TMS430 for example) need no external caps for 32 kHz xtal.
Try this to make sure T1OSC is used for RTCC: #pragma config RTCOSC = T1OSCREF
Working PIC RTCC example: datalogger
- zener
That was what I needed! Was running from the internal 31.125 KHZ RCoPossum wrote:Try this to make sure T1OSC is used for RTCC: #pragma config RTCOSC = T1OSCREF
Thanks! You have saved me a lot of time.
- zener
Oh great Possum,
Is there a way to modify just one calendar parameter, for example just minutes, if I wanted to adjust the time? Or do I have to read them all then write them all, including the changed one?
- opossum
RTCCFGbits.RTCPTR0 = 0; // Set pointer to seconds/minutes
RTCCFGbits.RTCPTR1 = 0;
RTCVALH = 0; // Set minutes
uint8_t min;
min = RTCVALH; // Get minutes
