ATmega32U4 Beginner Issues
For Adafruit customers who seek help with microcontrollers
Postby alexwitter » Tue Apr 17, 2012 10:21 pm
Hi everyone, I am pretty new to microcontroller programming. but I recently picked up a ATmega32u4 (received in a couple days, thanks), I know its not the best for a first attempt but I wanted to follow some of the LED tutorials on the site.
so basically I haven't really done much before I ran into some issue and spent 6 hours trying to fix it with no luck
Ok so I'm using OSX 10.7, I installed Ardiuno 1.0 Rc2, selected Leonardo as my board, connected up my ATmega32u4 and selected the new USB port tty.USBmodem411(also tried cu.USBmodem411). If I'm not mistaken this first time the "PWR"(red) and "boot"(green) light was solid, but since my attempted first upload the "boot"(green) green has been "breathing" (fading in and out reasonably fast). from the first flash where I pressed the reset button and tried to upload the blink example I have received:
avrdude: Send: 0 [30] [20]
avrdude: Recv: ? [3f]
avrdude: stk500_getsync(): not in sync: resp=0x3f
Any Ideas? should I attempt to get avrdude compiled and running to troubleshoot? is the bootloader confused?
Thanks in advance this is driving me nuts
Alex
alexwitter
Re: ATmega32U4 Beginner Issues
Postby adafruit_support_bill » Wed Apr 18, 2012 5:05 am
The timing on the reset can be a little tricky, try it a few more times.
Overall, avrdude is a better way to go.
Postby alexwitter » Thu Apr 19, 2012 1:36 pm
Thank for the speedy response, Actually after attempting on a windows PC and installing ATmega32u4 inf I manged to kick it out of the "Breathing" loop on my first upload attempt. I is now functioning as normal even back on the MAC. Although I do no receive any verification of a successful upload. and I can only get it working with the custom IDE that has ATmega32Uu4 in the board list available here http://www.ladyada.net/make/ledbelt/
Now is there anyway to get the ATmega32Uu4 working on Arduino 1.0 RC2. I am coming across a bunch of sketches that will not compile on the custom Arduino 1.0 IDE mentioned earlier. I have tried selecting Leonardo although I keep getting an out of sync issue. Any Idea?
Thanks again
alexwitter
Postby adafruit_support_bill » Thu Apr 19, 2012 3:22 pm
Is the problem that they won't compile, or that they won't upload? They are two different problems.
What is the exact text of the error message you see?
Postby alexwitter » Thu Apr 19, 2012 3:56 pm
As I stated "will not compile on the custom Arduino 1.0 IDE". Many will not even open (ie. .ino not .pde). (example neophob_SPI)
are you telling me that I should keep using the custom IDE that contains older code then attempting to get the board working on the newest software? (RC2)
alexwitter
Postby adafruit_support_bill » Thu Apr 19, 2012 4:31 pm
What is the exact text of the error you see.
Out of sync issues are not compile issues. They are upload issues.
Postby alexwitter » Tue Apr 24, 2012 1:46 pm
Everything works fine using Alpha 0021.I cannot even get blink uploaded using 1.0-RC2.
First when compiling with 1.0-RC2. i don't get a compile error but i do get two highlighted lines
/Applications/Arduino 2.app/Contents/Resources/Java/hardware/arduino/cores/arduino/USBCore.cpp: In function 'int USB_Send(u8, const void*, int)':
/Applications/Arduino 2.app/Contents/Resources/Java/hardware/arduino/cores/arduino/USBCore.cpp:266: warning: unused variable 'zero'
yet I'm still able to attempt an upload with these warnings. although with any sketch i try to upload using 1.0-RC2 i get:
System wide configuration file is "/Applications/Arduino 2.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/Users/alexwitter/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/tty.usbmodem411
Using Programmer : arduino
Overriding Baud Rate : 1200
avrdude done. Thank you.
again non of these problems occur using Alpha 0021 and selecting ATmega32U4
should I be selecting a different board other then Leonardo? any thoughts?
thanks again
alexwitter
Postby adafruit » Tue Apr 24, 2012 4:07 pm
The atmega 32u4 breakout is not a leonardo compatible, it is also not arduino compatible. http://www.ladyada.net/wiki/products/at ... index.html has details on how to use it. if you want to use the arduino IDE we suggest picking up a teensy
if this is your first board WE STRONGLY RECOMMEND YOU GET AN ARDUINO UNO (its even written in the product description! https://www.adafruit.com/products/296 :) )
Postby alexwitter » Tue Apr 24, 2012 5:45 pm
coincidentally withen the last week this page http://ladyada.net/make/adavision/was pulled down and public access revoked for http://www.ladyada.net/wiki/tutorials/adavision/start
I can guarantee without a shadow of a doubt that on this page http://www.ladyada.net/make/adavision/power.html
they explain to chose Leonardo from the board list when programing ATmega32U4.
i think an Uno is a much better idea, but i also don't like the idea of giving up, on such a simple concept.
alexwitter
Postby adafruit » Wed Apr 25, 2012 2:01 pm
that is because adavision is an unreleased, unsupported and incorrect tutorial. we will post it when its ready! there is no ETA when it will be ready.
Postby DJ4MC » Sat Apr 28, 2012 11:43 am
It looks like the tutorial is back for Adavision. I dont see any of the pics though and it looks the same. Not sure if you wanted it back up yet or not. BTW this is one of the coolest projects ever with huge potential for hacking/modding etc.
Go Adafruit Go!
Jules
DJ4MC
Postby adafruit » Mon Apr 30, 2012 3:15 pm
It should not be back up.
Postby DJ4MC » Mon Apr 30, 2012 4:52 pm
Sadness. I thought so. Anyway, it will be a most excellent project when it is ready. It is no longer up, just checked.
Jules
DJ4MC
Return to Microcontrollers
Users browsing this forum: No registered users and 4 guests
New Products [114]
Raspberry Pi[82]
FLORA[24]
mbed[12]
BeagleBone[23]
Young Engineers[39]
Project packs[9]
Breakout Boards[35]
LCDs & Displays[49]
Components & Parts[70]
Batteries & Power[54]
LEDs[112]
Wireless[16]
Cables[66]
Sensors/Parts[147]
Wearables[41]
Materials[25]
Books[26]
