G is for GROUND! The latest Circuit Playground is here!
AT89S51 USB
AT89S51 USB
by electronicfruit on Wed May 23, 2012 9:33 am
Is it possible to write directly on the USB pendrive using the AT89S51 MCU. I understand that UART of AT89S51 has to be converted into USB with the help of chips. Also there are modules out there which does this task.
However I want to make both hardware and write software from scratch : from sending data to the UART, then converting it to the USB and storing in a file on USB pen drive.
Anyone who could give starting points?
electronicfruit
Re: AT89S51 USB
by westfw on Thu May 24, 2012 1:22 am
No, it's not possible.
You should be able to write to an SD card, though.
westfw
