G is for GROUND! The latest Circuit Playground is here!
Problem with ATTiny85 timer1
by bryanduxbury on Wed Jun 06, 2012 11:20 am
I'm seeing some confusing behavior for timer1 on an ATTiny85. My end goal is to make a rig that allows for precise autocalibration of the internal oscillator by providing an external clock to sync against.
I'm using an approach I found here: http://www.avrfreaks.net/index.php?name ... 92&start=0. The basic gist is:
- 32.768kHz crystal hooked up to timer0
- timer1 set to free run with overflows counted
- after timer0 has overflowed, count the total number of ticks of timer1 (by shifting up the overflows)
- if the number of clocks was too high, drop OSCCAl a little; if it was too low, bump OSCCAL up a little
- repeat until we're within an error bound
This all seems like it should work, and indeed, I was able to play around and manually shift the OSCCAL value until it was precisely tuned. However, when I try to do it automatically, it doesn't work. After some debugging, I was able to determine that the number of ticks counted by timer1 was waay too low - something like 1/16th of what I expected.
This lead me to try and figure out why timer1 isn't doing what I expect. I set it up to output its signal directly to the OC1A pin so I could measure its frequency, and I was surprised to find that it was only 15.7kHz! As far as I can tell, I have completely disabled all prescalers and CTC functions, so it should just be a dump of the system clock. (And when I configure timer0 in that fashion, my oscilloscope's frequency counter gives up in terror, leading me to believe that timer is doing what I expected.)
Has anyone seen this sort of behavior before? Is there any sort of secret prescaler or setting that might have been turned on that would be causing this?
One last piece of information: I'm using the Arduino tiny core (from http://code.google.com/p/arduino-tiny/) and have made modifications that I believe would disable the millis timer behavior just for testing purposes. It is totally possible that someone more experienced than I could detect something about the timer bootup sequence that would be hard to disable.
bryanduxbury
Re: Problem with ATTiny85 timer1
by Coding Badly on Fri Jun 15, 2012 4:42 am
Something like this?
http://www.arduino.cc/cgi-bin/yabb2/YaB ... 1287558192
http://code.google.com/p/arduino-tiny/d ... =TinyTuner
Coding Badly
by stinkbutt on Fri Jul 27, 2012 4:15 pm
bryanduxbury wrote:This all seems like it should work, and indeed, I was able to play around and manually shift the OSCCAL value until it was precisely tuned. However, when I try to do it automatically, it doesn't work. After some debugging, I was able to determine that the number of ticks counted by timer1 was waay too low - something like 1/16th of what I expected.
The 1/16th thing STINKS of being a prescaler issue. It's exactly 1/16th? It's possible it's two issues simultaneously, because a 1:16 ratio doesn't strike me as being one that stands out, but there are places where the 8:1 ratio crops up.
To start with, please post your code. A schematic would be nice too, but the code is important. I'm particularly interested in where you set up stuff like the variable TCCR0. Also, did you screw around with your fuses? I doubt that you did. If you had you'd have likely prefaced your post with "So first I bricked a half-dozen chips..."
I don't reccomend you muck about with your fuses.
Red M&M, Blue M&M: They all wind up the same color
stinkbutt
