Burning bootloader to ATMEGA328P-AU-ND using AdaLoader
by jasonwebb on Tue Jun 19, 2012 2:51 pm
I assembled a little breakout board for an ATMEGA328P-AU-ND (http://www.digikey.com/product-detail/e ... ND/1832260) thinking that it was the same chip that is used by the Arduino main boards. Apparently, the "AU" part makes it a different chip, and I can't burn the bootloader using an UNO with ArduinoISP.
Whenever I connect my breakout board to the Arduino UNO (using digital pins 10, 11, 12 and 13 and power), then attempt to burn the bootloader using Arduino as ISP, I receive this error (Arduino 1.0.1):
avrdude: Yikes!  Invalid device signature.
         this check.
So, I loaded my UNO with the AdaLoader (https://github.com/adafruit/Standalone- ... programmer), hoping to get the device signature from the board so I can modify my boards.txt file (somehow). Here is the output in the Serial Monitor once I hit "G":
Reading signature:200
Searching for image...
 Not Found
Image fail
200? Haha, I thought there would be a hex value? Not sure how to proceed.
Did I buy the wrong ATMEGA328 chip? I wanted a 32-TQFN package, but maybe I got the wrong one. If not, does anyone have any idea how to get a bootloader onto it?
Jason Webb - grad student, creative technologist, OSHW engineer
  • Website: http://jason-webb.info
  • Twitter: @jasonwebb
  • Flickr: http://www.flickr.com/photos/zenwebb/
  • Vimeo: http://vimeo.com/jasonwebb
jasonwebb
Re: Burning bootloader to ATMEGA328P-AU-ND using AdaLoader
by jasonwebb on Tue Jun 19, 2012 3:30 pm
I downloaded WinAVR and used it's avrdude to check the device signature. It's 0x000000, which I guess means I fried my chip while soldering. Uh oh.
jasonwebb
