Burn Bootloader to ATmega328P-PU on a breadboard
by wrecks135 on Thu Jun 21, 2012 8:17 pm
I have an Arduino Uno R3 that I got here at Adafruit. I also recently purchased a ATmega328P-PU without the bootloader installed.
Can I simply use this setup to burn the bootloader onto the new microcontroller:
http://arduino.cc/en/Tutorial/ArduinoToBreadboard
It seems like people have mentioned problems doing this with the Uno...is that correct?
Rex
wrecks135
Re: Burn Bootloader to ATmega328P-PU on a breadboard
by philipm on Thu Jun 21, 2012 10:08 pm
I have done it many times, including using an uno R3.
philipm
by wrecks135 on Sat Jun 23, 2012 4:38 pm
I set this up as shown in the Arduino to Breadboard tutorial, loaded the ISP, selected Duemilanove w/ ATmega328 as my board, and then selected Burn Bootloader.
I got the following message:
avrdude: usbdev_open(): did not find any USB device "usb"
Does anybody have any suggestions?
Rex
wrecks135
by mrfu on Sun Jul 01, 2012 4:05 pm
What programmer did you select? When you selected the USBtiny device, it will look for a USB port.
But when you select the 'Arduino as ISP' option, it will start looking for a COM port.
So double check what programmer you have selected in the Arduino software.
(When using avrdude to flash the IC manually, just give avrdude the right port using the -P parameter. (Capitol P !))
mrfu
