Memorial day is 05/25/2015 – Orders will ship out on May 26th. There will not be any deliveries or shipping on Monday. Any order placed after 11am ET on Friday May 22nd will not start to ship out until Tuesday May 26th.
Help! Xmega Serial
Help! Xmega Serial
by qwertyboy on Mon Jul 30, 2012 5:31 pm
A couple weeks ago, I was on the Show and Tell with my quadcopter project. The hardware side is pretty much done, but now I need to start on the software/firmware side of things.
For development, I am using xmegaduino, which is a port of Arduino to use with xmega processors. Since none of the board configuration files that it comes with are for an xmega A3, which is what I am using, I need to make my own. I've got it pretty much figured out, but now I have hit a wall. Serial does not work!
Serial is pretty much a required peripheral, because of its great use in debugging, and I am having a heck of a time trying to get it working. Since there is not much activity on the xmegaduino project right now, I figured I'd come to (one of) the next best places.
I'm sure the best way to ask this, but please help me get serial working. I will include the pins_arduino.h and serial_init.cpp files, but if there are other ones that need to be looked, I can post those as well.
pins_arduino.h - This has been modified from an included Sparkfun board. It had an xmega A1
  pins_arduino.h - Pin definition functions for Arduino
  Part of Arduino - http://www.arduino.cc/
  Copyright (c) 2007 David A. Mellis
  This library is free software; you can redistribute it and/or
  modify it under the terms of the GNU Lesser General Public
  License as published by the Free Software Foundation; either
  version 2.1 of the License, or (at your option) any later version.
  This library is distributed in the hope that it will be useful,
  but WITHOUT ANY WARRANTY; without even the implied warranty of
  MERCHANTABILITY or banned FOR A PARTICULAR PURPOSE.  See the GNU
  Lesser General Public License for more details.
  You should have received a copy of the GNU Lesser General
  Public License along with this library; if not, write to the
  Free Software Foundation, Inc., 59 Temple Place, Suite 330,
  Boston, MA  02111-1307  USA
#ifndef Pins_Arduino_h
#define Pins_Arduino_h
#include <avr/pgmspace.h>
#define USE_RTC
#define REPEAT8(x) x, x, x, x, x, x, x, x
#define BV0TO7 _BV(0), _BV(1), _BV(2), _BV(3), _BV(4), _BV(5), _BV(6), _BV(7)
#define BV7TO0 _BV(7), _BV(6), _BV(5), _BV(4), _BV(3), _BV(2), _BV(1), _BV(0)
#define NUM_DIGITAL_PINS            47
#define NUM_ANALOG_INPUTS           16
#define EXTERNAL_NUM_INTERRUPTS     48
#define analogInputToDigitalPin(p)  ((p < 16) ? p : -1)
#define digitalPinHasPWM(p)         (((p) >= 16 && (p) <= 21) || ((p) >= 24 && (p)<= 29) || ((p) >= 32 && (p)<= 37))
static const uint8_t SS    = 20;
static const uint8_t MOSI  = 21;
static const uint8_t MISO  = 22;
static const uint8_t SCK   = 23;
static const uint8_t SS1   = 28;
static const uint8_t MOSI1 = 29;
static const uint8_t MISO1 = 30;
static const uint8_t SCK1  = 31;
//static const uint8_t SS2   = 36;
//static const uint8_t MOSI2 = 37;
//static const uint8_t MISO2 = 38;
//static const uint8_t SCK2  = 39;
//static const uint8_t SS3   = 44;
//static const uint8_t MOSI3 = 45;
//static const uint8_t MISO3 = 46;
//static const uint8_t SCK3  = 47;
static const uint8_t SDA = 16;
static const uint8_t SCL = 17;
static const uint8_t LED_BUILTIN = 13;
static const uint8_t A0 = 0;
static const uint8_t A1 = 1;
static const uint8_t A2 = 2;
static const uint8_t A3 = 3;
static const uint8_t A4 = 4;
static const uint8_t A5 = 5;
static const uint8_t A6 = 6;
static const uint8_t A7 = 7;
static const uint8_t A8 = 8;
static const uint8_t A9 = 9;
static const uint8_t A10 = 10;
static const uint8_t A11 = 11;
static const uint8_t A12 = 12;
static const uint8_t A13 = 13;
static const uint8_t A14 = 14;
static const uint8_t A15 = 15;
#define Wire xmWireC
#define Wire2 xmWireE
#define SPI_PORT   SPID
#define digitalPinToPCICR(p)    (((p) >= 0 && (p) <= 21) ? (&PCICR) : ((uint8_t *)0))
#define digitalPinToPCICRbit(p) (((p) <= 7) ? 2 : (((p) <= 13) ? 0 : 1))
#define digitalPinToPCMSK(p)    (((p) <= 7) ? (&PCMSK2) : (((p) <= 13) ? (&PCMSK0) : (((p) <= 21) ? (&PCMSK1) : ((uint8_t *)0))))
#define digitalPinToPCMSKbit(p) (((p) <= 7) ? (p) : (((p) <= 13) ? ((p) - 8) : ((p) - 14)))
#ifdef ARDUINO_MAIN
// these arrays map port names (e.g. port B) to the
// appropriate addresses for various functions (e.g. reading
// and writing)
const uint16_t PROGMEM port_to_PGM[] = {
   NOT_A_PORT,
   (uint16_t) &PORTA,
   (uint16_t) &PORTB,
   (uint16_t) &PORTC,
   (uint16_t) &PORTD,
   (uint16_t) &PORTE,
   //(uint16_t) &PORTF,
const uint8_t PROGMEM digital_pin_to_port_PGM[] = {
   // PORTLIST
   REPEAT8(PA), //  0 -  7
   REPEAT8(PB), //  8 - 15
   REPEAT8(PC), // 16 - 23
   REPEAT8(PD), // 24 - 31
   REPEAT8(PE), // 32 - 39
   //REPEAT8(PF), // 40 - 47
   //REPEAT8(PH), // 48 - 55
   //REPEAT8(PJ), // 56 - 63
   //REPEAT8(PK), // 64 - 71
const uint8_t PROGMEM digital_pin_to_bit_mask_PGM[] = {
   BV0TO7, // PORT A
   BV0TO7, // PORT B
   BV0TO7, // PORT C
   BV0TO7, // PORT D
   BV0TO7, // PORT E
   //BV0TO7, // PORT F
   //BV0TO7, // PORT H
   //BV0TO7, // PORT J
   //BV0TO7, // PORT K
const uint8_t PROGMEM digital_pin_to_timer_PGM[] = {
   //TIMERS
   NOT_ON_TIMER   , //PA
   NOT_ON_TIMER   ,
   NOT_ON_TIMER   ,
   NOT_ON_TIMER   ,
   NOT_ON_TIMER   ,
   NOT_ON_TIMER   ,
   NOT_ON_TIMER   ,
   NOT_ON_TIMER   ,
   NOT_ON_TIMER   , //PB
   NOT_ON_TIMER   ,
   NOT_ON_TIMER   ,
   NOT_ON_TIMER   ,
   NOT_ON_TIMER   ,
   NOT_ON_TIMER   ,
   NOT_ON_TIMER   ,
   NOT_ON_TIMER   ,
   TIMER_C0A   ,     //PC
   TIMER_C0B   ,
   TIMER_C0C   ,
   TIMER_C0D   ,
   TIMER_C1A   ,
   TIMER_C1B   ,
   NOT_ON_TIMER   ,
   NOT_ON_TIMER   ,
   TIMER_D0A   ,     //PD
   TIMER_D0B   ,
   TIMER_D0C   ,
   TIMER_D0D   ,
   TIMER_D1A   ,
   TIMER_D1B   ,
   NOT_ON_TIMER   ,
   NOT_ON_TIMER   ,
   TIMER_E0A   ,     //PE
   TIMER_E0B   ,
   TIMER_E0C   ,
   TIMER_E0D   ,
   TIMER_E1A   ,
   TIMER_E1B   ,
   NOT_ON_TIMER   ,
   NOT_ON_TIMER   ,
   //TIMER_F0A   ,     //PF
   //TIMER_F0B   ,
   //TIMER_F0C   ,
   //TIMER_F0D   ,
   //NOT_ON_TIMER   ,
   //NOT_ON_TIMER   ,
   //NOT_ON_TIMER   ,
   //NOT_ON_TIMER   ,
const TC0_t* PROGMEM timer_to_tc0_PGM[] = {
   NULL,
   &TCC0,
   &TCC0,
   &TCC0,
   &TCC0,
   NULL,
   NULL,
   &TCD0,
   &TCD0,
   &TCD0,
   &TCD0,
   NULL,
   NULL,
   &TCE0,
   &TCE0,
   &TCE0,
   &TCE0,
   NULL,
   NULL,
   //&TCF0,
   //&TCF0,
   //&TCF0,
   //&TCF0,
   //NULL,
   //NULL,
const TC1_t* PROGMEM timer_to_tc1_PGM[] = {
   NULL,
   NULL,
   NULL,
   NULL,
   NULL,
   &TCC1,
   &TCC1,
   NULL,
   NULL,
   NULL,
   NULL,
   &TCD1,
   &TCD1,
   NULL,
   NULL,
   NULL,
   NULL,
   &TCE1,
   &TCE1,
   //NULL,
   //NULL,
   //NULL,
   //NULL,
   //NULL,
   //NULL,
const uint8_t PROGMEM timer_to_channel_PGM[] = {
   NOT_ON_TIMER,
    0,
    1,
    2,
    3,
    0,
    1,
    0,
    1,
    2,
    3,
    0,
    1,
    0,
    1,
    2,
    3,
    0,
    1,
const uint8_t PROGMEM adc_to_channel_PGM[] = {
    0,
    1,
    2,
    3,
    4,
    5,
    6,
    7,
    8,
    9,
    10,
    11,
    12,
    13,
    14,
    15
#endif
#endif
serial_init.cpp
  serial_init.cpp - Initialize serial ports for Arduino
  Copyright (c) 2011 Karl Backstroem
// Preinstantiate Objects //////////////////////////////////////////////////////
#define SERIAL_DEFINE(name, usart_port, port_nr) \
ring_buffer name##rx_buffer = { { 0 }, 0, 0 }; \
ISR(USART##usart_port##port_nr##_RXC_vect) \
  unsigned char c = USART##usart_port##port_nr.DATA; \
  store_char(c, &name##rx_buffer); \
HardwareSerial name (&name##rx_buffer, &USART##usart_port##port_nr, &PORT##usart_port, (port_nr ? PIN6_bm : PIN2_bm), (port_nr ? PIN7_bm : PIN3_bm));
SERIAL_DEFINE(Serial, C, 0);
SERIAL_DEFINE(Serial1, C, 1);
SERIAL_DEFINE(Serial2, D, 0);
SERIAL_DEFINE(Serial3, D, 1);
SERIAL_DEFINE(Serial4, E, 0);
yo
qwertyboy
