Help! Xmega Serial
Help! Xmega Serial
by qwertyboy on Mon Jul 30, 2012 5:31 pm
A couple weeks ago, I was on the Show and Tell with my quadcopter project. The hardware side is pretty much done, but now I need to start on the software/firmware side of things.
For development, I am using xmegaduino, which is a port of Arduino to use with xmega processors. Since none of the board configuration files that it comes with are for an xmega A3, which is what I am using, I need to make my own. I've got it pretty much figured out, but now I have hit a wall. Serial does not work!
Serial is pretty much a required peripheral, because of its great use in debugging, and I am having a heck of a time trying to get it working. Since there is not much activity on the xmegaduino project right now, I figured I'd come to (one of) the next best places.
I'm sure the best way to ask this, but please help me get serial working. I will include the pins_arduino.h and serial_init.cpp files, but if there are other ones that need to be looked, I can post those as well.
pins_arduino.h - This has been modified from an included Sparkfun board. It had an xmega A1
  pins_arduino.h - Pin definition functions for Arduino
  Part of Arduino - http://www.arduino.cc/
  Copyright (c) 2007 David A. Mellis
  This library is free software; you can redistribute it and/or
  modify it under the terms of the GNU Lesser General Public
  License as published by the Free Software Foundation; either
  version 2.1 of the License, or (at your option) any later version.
  This library is distributed in the hope that it will be useful,
  but WITHOUT ANY WARRANTY; without even the implied warranty of
  MERCHANTABILITY or banned FOR A PARTICULAR PURPOSE.  See the GNU
  Lesser General Public License for more details.
  You should have received a copy of the GNU Lesser General
  Public License along with this library; if not, write to the
  Free Software Foundation, Inc., 59 Temple Place, Suite 330,
  Boston, MA  02111-1307  USA
#ifndef Pins_Arduino_h
#define Pins_Arduino_h
#include <avr/pgmspace.h>
#define USE_RTC
#define REPEAT8(x) x, x, x, x, x, x, x, x
#define BV0TO7 _BV(0), _BV(1), _BV(2), _BV(3), _BV(4), _BV(5), _BV(6), _BV(7)
#define BV7TO0 _BV(7), _BV(6), _BV(5), _BV(4), _BV(3), _BV(2), _BV(1), _BV(0)
#define NUM_DIGITAL_PINS            47
#define NUM_ANALOG_INPUTS           16
#define EXTERNAL_NUM_INTERRUPTS     48
#define analogInputToDigitalPin(p)  ((p < 16) ? p : -1)
#define digitalPinHasPWM(p)         (((p) >= 16 && (p) <= 21) || ((p) >= 24 && (p)<= 29) || ((p) >= 32 && (p)<= 37))
static const uint8_t SS    = 20;
static const uint8_t MOSI  = 21;
static const uint8_t MISO  = 22;
static const uint8_t SCK   = 23;
static const uint8_t SS1   = 28;
static const uint8_t MOSI1 = 29;
static const uint8_t MISO1 = 30;
static const uint8_t SCK1  = 31;
//static const uint8_t SS2   = 36;
//static const uint8_t MOSI2 = 37;
//static const uint8_t MISO2 = 38;
//static const uint8_t SCK2  = 39;
//static const uint8_t SS3   = 44;
//static const uint8_t MOSI3 = 45;
//static const uint8_t MISO3 = 46;
//static const uint8_t SCK3  = 47;
static const uint8_t SDA = 16;
static const uint8_t SCL = 17;
static const uint8_t LED_BUILTIN = 13;
static const uint8_t A0 = 0;
static const uint8_t A1 = 1;
static const uint8_t A2 = 2;
static const uint8_t A3 = 3;
static const uint8_t A4 = 4;
static const uint8_t A5 = 5;
static const uint8_t A6 = 6;
static const uint8_t A7 = 7;
static const uint8_t A8 = 8;
static const uint8_t A9 = 9;
static const uint8_t A10 = 10;
static const uint8_t A11 = 11;
static const uint8_t A12 = 12;
static const uint8_t A13 = 13;
static const uint8_t A14 = 14;
static const uint8_t A15 = 15;
#define Wire xmWireC
#define Wire2 xmWireE
#define SPI_PORT   SPID
#define digitalPinToPCICR(p)    (((p) >= 0 && (p) <= 21) ? (&PCICR) : ((uint8_t *)0))
#define digitalPinToPCICRbit(p) (((p) <= 7) ? 2 : (((p) <= 13) ? 0 : 1))
#define digitalPinToPCMSK(p)    (((p) <= 7) ? (&PCMSK2) : (((p) <= 13) ? (&PCMSK0) : (((p) <= 21) ? (&PCMSK1) : ((uint8_t *)0))))
#define digitalPinToPCMSKbit(p) (((p) <= 7) ? (p) : (((p) <= 13) ? ((p) - 8) : ((p) - 14)))
#ifdef ARDUINO_MAIN
// these arrays map port names (e.g. port B) to the
// appropriate addresses for various functions (e.g. reading
// and writing)
const uint16_t PROGMEM port_to_PGM[] = {
   NOT_A_PORT,
   (uint16_t) &PORTA,
   (uint16_t) &PORTB,
   (uint16_t) &PORTC,
   (uint16_t) &PORTD,
   (uint16_t) &PORTE,
   //(uint16_t) &PORTF,
const uint8_t PROGMEM digital_pin_to_port_PGM[] = {
   // PORTLIST
   REPEAT8(PA), //  0 -  7
   REPEAT8(PB), //  8 - 15
   REPEAT8(PC), // 16 - 23
   REPEAT8(PD), // 24 - 31
   REPEAT8(PE), // 32 - 39
   //REPEAT8(PF), // 40 - 47
   //REPEAT8(PH), // 48 - 55
   //REPEAT8(PJ), // 56 - 63
   //REPEAT8(PK), // 64 - 71
const uint8_t PROGMEM digital_pin_to_bit_mask_PGM[] = {
   BV0TO7, // PORT A
   BV0TO7, // PORT B
   BV0TO7, // PORT C
   BV0TO7, // PORT D
   BV0TO7, // PORT E
   //BV0TO7, // PORT F
   //BV0TO7, // PORT H
   //BV0TO7, // PORT J
   //BV0TO7, // PORT K
const uint8_t PROGMEM digital_pin_to_timer_PGM[] = {
   //TIMERS
   NOT_ON_TIMER   , //PA
   NOT_ON_TIMER   ,
   NOT_ON_TIMER   ,
   NOT_ON_TIMER   ,
   NOT_ON_TIMER   ,
   NOT_ON_TIMER   ,
   NOT_ON_TIMER   ,
   NOT_ON_TIMER   ,
   NOT_ON_TIMER   , //PB
   NOT_ON_TIMER   ,
   NOT_ON_TIMER   ,
   NOT_ON_TIMER   ,
   NOT_ON_TIMER   ,
   NOT_ON_TIMER   ,
   NOT_ON_TIMER   ,
   NOT_ON_TIMER   ,
   TIMER_C0A   ,     //PC
   TIMER_C0B   ,
   TIMER_C0C   ,
   TIMER_C0D   ,
   TIMER_C1A   ,
   TIMER_C1B   ,
   NOT_ON_TIMER   ,
   NOT_ON_TIMER   ,
   TIMER_D0A   ,     //PD
   TIMER_D0B   ,
   TIMER_D0C   ,
   TIMER_D0D   ,
   TIMER_D1A   ,
   TIMER_D1B   ,
   NOT_ON_TIMER   ,
   NOT_ON_TIMER   ,
   TIMER_E0A   ,     //PE
   TIMER_E0B   ,
   TIMER_E0C   ,
   TIMER_E0D   ,
   TIMER_E1A   ,
   TIMER_E1B   ,
   NOT_ON_TIMER   ,
   NOT_ON_TIMER   ,
   //TIMER_F0A   ,     //PF
   //TIMER_F0B   ,
   //TIMER_F0C   ,
   //TIMER_F0D   ,
   //NOT_ON_TIMER   ,
   //NOT_ON_TIMER   ,
   //NOT_ON_TIMER   ,
   //NOT_ON_TIMER   ,
const TC0_t* PROGMEM timer_to_tc0_PGM[] = {
   NULL,
   &TCC0,
   &TCC0,
   &TCC0,
   &TCC0,
   NULL,
   NULL,
   &TCD0,
   &TCD0,
   &TCD0,
   &TCD0,
   NULL,
   NULL,
   &TCE0,
   &TCE0,
   &TCE0,
   &TCE0,
   NULL,
   NULL,
   //&TCF0,
   //&TCF0,
   //&TCF0,
   //&TCF0,
   //NULL,
   //NULL,
const TC1_t* PROGMEM timer_to_tc1_PGM[] = {
   NULL,
   NULL,
   NULL,
   NULL,
   NULL,
   &TCC1,
   &TCC1,
   NULL,
   NULL,
   NULL,
   NULL,
   &TCD1,
   &TCD1,
   NULL,
   NULL,
   NULL,
   NULL,
   &TCE1,
   &TCE1,
   //NULL,
   //NULL,
   //NULL,
   //NULL,
   //NULL,
   //NULL,
const uint8_t PROGMEM timer_to_channel_PGM[] = {
   NOT_ON_TIMER,
    0,
    1,
    2,
    3,
    0,
    1,
    0,
    1,
    2,
    3,
    0,
    1,
    0,
    1,
    2,
    3,
    0,
    1,
const uint8_t PROGMEM adc_to_channel_PGM[] = {
    0,
    1,
    2,
    3,
    4,
    5,
    6,
    7,
    8,
    9,
    10,
    11,
    12,
    13,
    14,
    15
#endif
#endif
serial_init.cpp
  serial_init.cpp - Initialize serial ports for Arduino
  Copyright (c) 2011 Karl Backstroem
// Preinstantiate Objects //////////////////////////////////////////////////////
#define SERIAL_DEFINE(name, usart_port, port_nr) \
ring_buffer name##rx_buffer = { { 0 }, 0, 0 }; \
ISR(USART##usart_port##port_nr##_RXC_vect) \
  unsigned char c = USART##usart_port##port_nr.DATA; \
  store_char(c, &name##rx_buffer); \
HardwareSerial name (&name##rx_buffer, &USART##usart_port##port_nr, &PORT##usart_port, (port_nr ? PIN6_bm : PIN2_bm), (port_nr ? PIN7_bm : PIN3_bm));
SERIAL_DEFINE(Serial, C, 0);
SERIAL_DEFINE(Serial1, C, 1);
SERIAL_DEFINE(Serial2, D, 0);
SERIAL_DEFINE(Serial3, D, 1);
SERIAL_DEFINE(Serial4, E, 0);
yo
qwertyboy
cron
