atmega32u4 breakout wont enumerate...
by niknak on Tue Sep 25, 2012 8:13 am
Hello all.
I'm having some issues with the atmega32u4 breakout board.
Perhaps someone here might be able to help?
I purchased this back in November 2011, so i think originally it was runing the leonardo bootloader.
Since its been a while, I checked out the latest bootloader from ada's github repo.
https://github.com/adafruit/Atmega32u4-Breakout-Board/blob/master/BootloaderCDC.hex
i then used my buspirate to write that new bootloader to the atmega32u4. Output is below:
~/git/micro/atmega32u4/Atmega32u4-Breakout-Board: master ✖  avrdude -c buspirate -p m32u4 -P /dev/tty.usbserial-A900F4DA  flash:w:BootloaderCDC.hex
Detecting BusPirate...
**  Bus Pirate v3b
**  Firmware v5.10 (r559)  Bootloader v4.4
**  DEVID:0x0447 REVID:0x3043 (24FJ64GA002 B5)
**  http://dangerousprototypes.com
BusPirate: using BINARY mode
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.10s
avrdude: Device signature = 0x1e9587
avrdude: safemode: Fuses OK
avrdude done.  Thank you.
~/git/micro/atmega32u4/Atmega32u4-Breakout-Board: master ✖  avrdude -c buspirate -p m32u4 -P /dev/tty.usbserial-A900F4DA  -U flash:w:BootloaderCDC.hex
**  Bus Pirate v3b
avrdude: NOTE: FLASH memory has been specified, an erase cycle will be performed
         To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "BootloaderCDC.hex"
avrdude: input file BootloaderCDC.hex auto detected as Intel Hex
avrdude: writing flash (32442 bytes):
Writing | ################################################## | 100% 1044.99s
avrdude: 32442 bytes of flash written
avrdude: verifying flash memory against BootloaderCDC.hex:
avrdude: load data flash data from input file BootloaderCDC.hex:
avrdude: input file BootloaderCDC.hex contains 32442 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 1037.05s
avrdude: verifying ...
avrdude: 32442 bytes of flash verified
Avrdude is so polite!
Now.. here's my problem: When i plug in my breakout board, the power light is on, the green boot light is "breathing", but my mac won't enumerate the device.
Its not showing up in /dev/tty.usb* and when i checked the system log i found this:
9/25/12 7:05:25.000 AM kernel: USBF:   8849.711   [0xffffff802033f600] The IOUSBFamily is having trouble enumerating a USB device that has been plugged in.  It will keep retrying.  (Port 2 of Hub at 0xfd100000)
9/25/12 7:05:28.000 AM kernel: USBF:   8852.713   [0xffffff802033f600] The IOUSBFamily was not able to enumerate a device.
I've tried writing the bootloader again just to make sure, but with the same result.
I'm stuck. :(
niknak
Re: atmega32u4 breakout wont enumerate...
by niknak on Tue Sep 25, 2012 8:27 am
thought this might prove helpful as well: this is the results of running avrdude with verbose output:
~/git/micro/atmega32u4/Atmega32u4-Breakout-Board: master ✖  avrdude -c buspirate -p m32u4 -P /dev/tty.usbserial-A900F4DA  -v
avrdude: Version 5.11, compiled on Nov 10 2011 at 19:19:04
         Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "/usr/local/Cellar/avrdude/5.11/etc/avrdude.conf"
         User configuration file is "/Users/NicholasWagner/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/tty.usbserial-A900F4DA
         Using Programmer              : buspirate
         AVR Part                      : ATmega32U4
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    10     8    0 no       1024    8      0  9000  9000 0x00 0x00
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : BusPirate
         Description     : The Bus Pirate
avrdude: buspirate_readline(): #
avrdude: buspirate_readline(): RESET
avrdude: buspirate_readline(): Bus Pirate v3b
**  Bus Pirate v3b
avrdude: buspirate_readline(): Firmware v5.10 (r559)  Bootloader v4.4
avrdude: buspirate_readline(): DEVID:0x0447 REVID:0x3043 (24FJ64GA002 B5)
avrdude: buspirate_readline(): http://dangerousprototypes.com
avrdude: buspirate_readline(): HiZ>
BusPirate binmode version: 1
BusPirate SPI version: 1
avrdude: safemode: lfuse reads as DE
avrdude: safemode: hfuse reads as DA
avrdude: safemode: efuse reads as CB
BusPirate is back in the text mode
niknak
by adafruit_support_bill on Tue Sep 25, 2012 9:53 am
You might try a different port. Preferably not a USB 3.0 port. If you don't have any USB 2.0 ports, try connecting through a USB 2.0 hub.
by westfw on Tue Sep 25, 2012 10:44 am
Are the fuses and lock bits correct? Your avrdude log doesn't show the explicit setting of fuses that is normally done when programming a bootloader. to ensure things like the boot area start address being set appropriately.
You can find the expected settings in the Makefile. Looks like:
$(AVRDUDE) $(AVRDUDE_FLAGS) -U lfuse:w:0xFC:m -U hfuse:w:0xD0:m -U efuse:w:0xF3:m
$(AVRDUDE) $(AVRDUDE_FLAGS) $(AVRDUDE_WRITE_FLASH) $(AVRDUDE_WRITE_EEPROM)
$(AVRDUDE) $(AVRDUDE_FLAGS) -U lock:w:0x2F:m
westfw
by niknak on Tue Sep 25, 2012 11:05 am
Thanks guys,
I'll give it another go tonight and post the results! :)
niknak
