Measuring Gas-Tank Level via Microcontroller?
by miax on Fri Oct 26, 2012 2:36 pm
Maker Community,
Hello! My first robot project will involve turning my snow blowing into a autonimous droid that I will control via live video feed from my house. :) It will require both an Arudino Mega and a Rasberry Pi working together along with a dozen HiTec Servos (some waterproof, some super-troque), one electric motor and TONS of Adafruit electronics! 8)
I have two challenges that I don't know how to overcome, this thread addresses the first; understanding how much gas is left in the tank (so the droid will know when to drive home for fuel).
Is there a Safe sensor that I can use to measure fuel-level in the gas tank ,shown below via my Arduino Microcontroller?
Snapper Snow Blower - Pre-Modification
Thanks in advance!!
Kris
Kristopher Kortright
Father, Husband, Horseman, Maker, Writer, Internet Technologist and Inventor of Strange of Useful Things
Supporter of the Open Source Hardware movement
miax
Re: Measuring Gas-Tank Level via Microcontroller?
by franklin97355 on Fri Oct 26, 2012 5:28 pm
You could install a "sightglass" on the tank and use IR sensors to get the level of the gas in the glass.
franklin97355
by john444 on Fri Oct 26, 2012 11:06 pm
Hi Kris,
I think you might use something like this gas-cap to start:
http://www.amazon.com/fuel-gauge-Simplicity-171252-2171252/dp/B000NEAM92/ref=pd_sim_sbs_lg_5
The cork on the twisted shaft rotates the pointer about 270° from full to empty.
You might use a optical coupler to detect the empty position or use an encoder to detect position.
I imagine riding on the snow-blower is going to be a rough environment -
hot, cold, vibrating like crazy, wet, greasy, gasoline vapors. Lots of rough stuff.
Good Luck, John
john444
by apastump on Sat Oct 27, 2012 5:14 am
Curious topic
apastump
by miax on Sat Oct 27, 2012 10:22 am
Hi John!
Thank you again for the great suggestion! I took advantage of your advice and just ordered one from Amazon. :)
You also gave me pause about the environment - I had considered the hot, cold, wet, greasy and vapors, but I had forgotten how bad they vibrate!
I took some time this morning and adjusted my designs accordingly, I will post them in a bigger post about the project when I'm more ready. I'm still gathering the parts and improving my 3D printers environment to cut-out the drafts (as I'll need to print several parts for the project).
Thanks again John! I'll definitely give you proper mention in the credits!
Cheers,
Kris
miax
