Tiny 45/85 alternative.
by kculm on Thu Dec 27, 2012 3:27 pm
Hi All
I was wondering if there is an alternative to using the Tiny 45 or 85. I with a few more pins.
kculm
Re: Tiny 45/85 alternative.
by xl97 on Thu Dec 27, 2012 6:03 pm
maybe one of these will work for you:
xl97
by kewakl on Thu Dec 27, 2012 10:17 pm
@xl97, I cannot see your image
@kculm, what about ATtiny2313?
2K flash
20Mhz
20 pins
18 I/O pins (17 if you use PA2 as a reset pin)
kewakl
by xl97 on Thu Dec 27, 2012 10:21 pm
hmm.. shows up for me (at home and at work)..
link: http://arduino.cc/forum/index.php?actio ... 0315;image
xl97
by kewakl on Thu Dec 27, 2012 10:29 pm
OK, had to log in to arduino.cc forum.
it works now. thanks!
kewakl
by kculm on Thu Dec 27, 2012 11:04 pm
Ok Guys,
I picked up some 85 just to start playing with. I have run though all the Tuts I can find but I am having no luck programming it. I keep get errors what I get the part Burn Boot loader. ( I will post the Errors once I get it set back up.
I am using Arduino 1.0.3 and AtTiny85 20MHz.
Anyone know of any Issues with that config.
kculm
by BruceF on Thu Dec 27, 2012 11:40 pm
This page* says that Arduino 1.0.2 doesn't work with the ATtiny85, or at least not with some particular Arduino ATtiny interface drivers. Maybe that was fixed in 1.0.3 or doesn't relate to the Arduino software you're working with at all, but perhaps you need to back up to 1.0.1, like they suggest? Just an idea, I'm only using ATmega328's at the moment myself.
* http://hlt.media.m i t.edu/?p=1695 - you'll have to remove the spaces in M I T yourself, since the spam filter apparently came from Harvard.
- Bruce
BruceF
by greywuuf on Fri Dec 28, 2012 12:54 am
A higher pin count alternative to the 25/45/85 series is the 84 a 14 pin chip.
I am using 85's with 1.0.2 though I am using cores from the Google core site.
I will post a link when I get back home and to my computer. Also try burning the 1 MHz boot loader first....then selecting another.....I read somewhere it was a work around.
greywuuf
by greywuuf on Fri Dec 28, 2012 12:59 am
These cores work for me with arduino 1.0.2.
http://code.google.com/p/arduino-tiny/
greywuuf
by greywuuf on Fri Dec 28, 2012 1:17 am
Also there is some good info on tiny with arduino IDE here.
http://harizanov.com/category/attiny85/
greywuuf
