Arduino Micro and AC to USB power adapter?
by marcalex on Sun Jan 27, 2013 6:48 pm
Hello Adafruit,
I own an Apple AC to USB adapter and I'm wondering if it's safe to use to power the Arduino Micro. The specs on the adapter say:
    Input: 100-240V ~ 50/60Hz 0.15A
    Output: 5V --- 1A
I've also attached a photo of the adapter.
thanks,
Marc
marcalex
Re: Arduino Micro and AC to USB power adapter?
by adafruit_support_rick on Sun Jan 27, 2013 7:24 pm
Should be fine.
by marcalex on Mon Jan 28, 2013 2:29 pm
Hi driverblock,
The technical details at http://www.adafruit.com/products/1086 state:
    Input Voltage (limits): 6-20V
The output of the adapter is 5V. Am I reading the spec correctly to think that the voltage output is too low?
thanks,
Marc
marcalex
by adafruit_support_rick on Mon Jan 28, 2013 2:49 pm
Those are the voltage limits for power supplies plugged into the barrel jack. That goes through the voltage regulator, where there is some dropout in generating the 5V operating voltage.
The Apple adapter, on the other hand, will be providing regulated 5V through the USB port. This bypasses the arduino's voltage regulator, and the 5V is used directly. It's the same as powering the arduino by plugging it into a computer's USB port - those also provide 5V.
by marcalex on Tue Jan 29, 2013 10:07 am
Thanks driverblock, I appreciate your help :)
marcalex
